Old 01-28-2010, 08:15 PM
Mike Norris is the best I have ever seen with LS motors.
Frank Serafine
Old 01-28-2010, 08:19 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Matt, are you running an E38 ECM? Mass air or speed density?
Great numbers!
My LS7 69 Camaro
Old 01-28-2010, 09:32 PM
Look at that air/fuel, it's one of the best I've ever seen. Crazy good numbers out of a 427 with that little cam.
Old 01-28-2010, 09:40 PM
KPC67's Avatar
KPC67 KPC67 is offline
It's a long ways away but I have been wondering who I will get to help me with this up in Canada when the time comes...
Kevin Carter
Old 01-29-2010, 06:45 PM
Chicken Louie's Avatar
Chicken Louie Chicken Louie is offline
KPC 67,
James Hatfield at HorsePower Solutions in Edmonton is a name I have heard a few times up here in Alberta.
Dave
Old 01-29-2010, 07:43 PM
KPC67's Avatar
Originally Posted by Chicken Louie View Post
KPC 67,
Dave
I will look into him.. thanks
Kevin Carter
Old 02-03-2010, 04:34 PM
BillyBobL71's Avatar
BillyBobL71 BillyBobL71 is offline
Default Awesome Results
Matt,
That is one fine Dyno sheet. Am changing my LS2 for an LS7, and would be elated to achieve the same results. Can you tell us what ALL you have done to your motor? And what gears are you running?
Thanks,
Billy Bob
Old 02-03-2010, 06:39 PM
James OLC's Avatar
Davenport in Calgary should be able to help you out - they seem to have one of the best handles on LS engines that I know of in "the neighborhood". Good luck
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 01-29-2010, 05:28 AM
MattG's Avatar
MattG MattG is offline
Great numbers!
I've got the old 24 tooth from Speartech. I wanted cruise control and at the time that was the only option. Did you ever get your cruise to work?
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 01-29-2010, 06:05 AM
XcYZ's Avatar
No, I haven't really looked any more into cruise control. It would sure be nice on the Power Tour.
Yep, that cam is small, but the LS7 heads are great right out of the box. Look at the out of the box flow numbers, 360cfm at .600". The Torquer gives up some power above 6600, but it makes up for it with great mid-range torque. I've thought about doing a cam swap just to try something new, but my car runs so well - cold/hot starts/idle/driveabilty/etc - I don't want to change it. lol It traps 124mph weiging in over 3500 with me in it, so it's making decent power.
I had my car on a chassis dyno when it was brand new, and with only 19* of total timing (had intended on spraying it on the dyno, but never did), it made 500rwhp.
I'd like to get it back on the chassis dyno now that it's fully broke in and see what numbers it will make with the full 26* of timing.
My LS7 69 Camaro
