Old 02-07-2010, 04:56 PM
scherp69's Avatar
scherp69 scherp69 is offline
Just checked the Moser website...it is 3" O.D. The back brace is hollow. Where on the housing would the clamp fit? with mine, there is a bracket on the top for the short arms and on the bottom (you can see in the first pic) I welded on the bracket for the rear sway bar. I would be interested to see what you have in mind though.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 02-08-2010, 05:10 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
You can mount the clamp on the space between the welded shock mount & the end of the brace.. rotate the clamp so that you can plumb on top of the brace instead of the center of the brace like the pic attached.. or fabricate an L shaped bracket that you can drill to the hollow end of the brace..
I hope this pic helps!
Cris Gonzalez
Old 05-29-2013, 08:36 AM
R4VEN R4VEN is offline
Default Are any of these clamps still availble?
I need a couple of these clamps. Are any left?
Old 05-30-2013, 08:47 AM
Brian - JCG Brian - JCG is offline
Yes, we still stock these. Ironically enough, we just sent our last set out a few days ago. We do have more coming, but will probably be a week or two before they are here..
Brian Short
www.JCGRestorationandCustoms.com
