Old 02-27-2010, 06:49 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Great numbers! That's the way to do it right - relatively light weight and awesome power.
Old 02-27-2010, 07:29 AM
cdushane's Avatar
cdushane cdushane is offline
That thing sounds and looks absolutely killer
Old 02-27-2010, 07:35 AM
g356gear's Avatar
g356gear g356gear is offline
GREAT looking motor....what heads are you running? Still running the same heads as before?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 02-27-2010, 07:44 AM
Payton King's Avatar
Default so have you
dropped it in yet. lol
great numbers, you have to be excited can't wait for the driving impressions
Old 02-27-2010, 07:57 AM
JustinB's Avatar
JustinB JustinB is offline
Bad ass! Jealous. What are cam specs? Congrats on the new motor and for sticking to your guns and running a carbed big block. There are only of a few of us left. Now get out there and kick the crap out of some LSX motors!!
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 02-27-2010, 08:01 AM
Appreciate it... It's still in the back of the truck. After 6 hours of driving Kelli took me out and treated me to some Buffalo Wild Wings. I'll have it out on the stand this morning. That's the first thing Jason said 666. I have a feeling I'm going to get tired of that tongue twister.
It does have a Edelbrock RPM air gap. From my research with a single plane it probably would of made 685-700hp easy but lost just as much or more low end torque. Moving the peak torque up in the 5000's. While great for bragging rights it wouldn't be ideal for Autocross or the street. Once again, trying to walk the fence between race a street. We ran it exactly as it will be in the car, operating temps, 1/2 phelonic spacer, and 34 degrees of timing. I have to admit I said" Let's throw a 1 inch spacer and a dominator on it" just for fun. He didn't have a dominator handy and I was ready to get on the road so we decided against the test with the 1 inch spacer . We ended up 7 jet sizes down from the old engine. The first 5 picked up about 20-30 hp and 10-15lbft. The other 2 picked up about 5 and we called it good. It is the same heads with some pocket porting. They are Dart 320's that have been shaved and the block is zero deck. It's right at 10.23:1. The cam is really about the same size as the old hydraulic with 252/260 @ 50 .666/.667 lift on a 110 installed on IC 105.5. When you factor in lash it's got just a little more lift. Once again, wanting something reasonable for valvetrain reliability and streetable. The stud girdle is for the high rpm abuse since it has over 600 open pressure. Jason told me I could set the rev limiter at 7200 but I'm going to set it lower. Probably 6800-7000.
Old 02-27-2010, 09:30 AM
monza's Avatar
monza monza is offline
Thats super tight!!
-my wife just asked, "how come your so happy looking at some guys engine make noise." I tried to explain, it's not just some guys engine.... some things can't be explained.
Burn outs next!
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 02-27-2010, 09:35 AM
DFRESH's Avatar
DFRESH DFRESH is offline
All alluminum big block chevy---how can you go wrong---that is so bad A man. Congrads. I am getting seriously pumped about April's RTTH and the Coastal cruise in June--especially after hearing that motor on the dyno---way to go brother. Can't wait to hear it in person.
Doug
Old 02-27-2010, 10:47 AM
1badchevelle 1badchevelle is offline
It must really suck to be you. LOL
Great numbers, I take it a couple of new rear tires came with the motor?
Old 02-27-2010, 11:05 AM
Rybar's Avatar
Rybar Rybar is offline
Motor sounds awesome Todd, congrats on the new combo and numbers
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
