Old 03-25-2010, 02:31 PM
Manual brakes work GREAT -- and there's no good reason to run power brakes. The key to good manual brakes is the proper master cylinder for your combination - and the pedal ratio. If I was doing disc front drum rear - I'd run a 1" wilwood master cylinder - and a 6 or 7:1 pedal ratio.
Power brakes are 4:1 pedal ratio.
Talk to the boys at KORE3 - Just google it... and see what they advise you.
Old 03-26-2010, 03:40 PM
68 454 EFI's Avatar
68 454 EFI 68 454 EFI is offline
Thanks for the advise, I think i'm definitely going to go with the manual set up. Just gotta find the best deal, on the best set up. Thanks again guys.
Old 03-26-2010, 04:31 PM
JustinB's Avatar
JustinB JustinB is offline
BBC with very little vacuum and running a manual Wilwood front/rear setup with a 7/8 bore master. Hit the pedal hard and if you are not paying attention and you will bury yourself into the steering wheel. We have a number of kits that we can offer you. Feel free to call, PM, or email for pricing and info.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 03-26-2010, 05:55 PM
How well the manual brakes work depends a lot on how the system was designed. If you use a system that was designed as a power assist system, there is a delicate line in getting the volume / pressure right. A system like Wilwood will work great as a manual system because it is designed to be a manual system, but you can run power assist if you choose.
We sell more then half our Wilwood Total Car G Machine Brake packages as manual systems as many of our cars and customers cars are big HP, big cam, or blown turbo / blower cars, that make little vacuum.
It gets a little tricky with getting proper pedal feel and volume with disc / drums. The small bore / high pressure master does not work great with disc / drum set ups. A larger bore works much better for volume but makes for a fairly firm pedal. So it really becomes a one or the other situation.
I could talk for hours on the subject. But I type with 2 fingers, LOL!
Frank Serafine
Old 04-22-2010, 05:19 PM
Taman Taman is offline
Default pedal ratio
How do you change the pedal ratio on a 2nd gen TA?
Old 04-22-2010, 08:28 PM
The WidowMaker's Avatar
its all about where the hole is located on the pedal. if you move your foot 6" and the pushrod moves 1" you have a 6:1. its just the ratio from the pivot point of the pedal to the mounting point of the pushrod and from the pivot point of the pedal to the foot pad on the pedal.
"The WidowMaker"
Old 04-22-2010, 09:13 PM
It's the length of the pedal arm and distance from the pivot point to the pushrod. If the distance from the pivot point to the pushrod hole gets to short, you sacrifice piston stroke.
I'm switching to a 1" bore master in my manual system. 7/8 is great in a street car but it's got it's drawback on the track.
I diagree Greg. There are advantages of power systems. It covers up brake pad knockback with a much larger piston. It's also better in a daily driver. How many factory cars have manual brakes?
Old 04-22-2010, 09:35 PM
Not sure where you got that info -- but it's pure crappola....
If you can move your brake pedal 6" -- you'd have your foot on the FLOORBOARD....
Old 04-22-2010, 09:29 PM
I'd second that thought -- My 7/8" Wilwood manual master / Baer brake (disc all 4)... will throw you right thru the window if you want them to ---- and for driving around town - they require very little effort.
