Closed Thread
Old 03-26-2010, 03:26 PM
g356gear's Avatar
g356gear g356gear is offline
Hey Todd, in my experience, usually when you make hp jumps like this, you find the weak links in the powertrain pretty quick. Are you worried about the TKO 600 tranny handling past 500-600 ft.lbs?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 03-26-2010, 03:34 PM
Nope, if it breaks I'll replace it. That t56 magnum looks interesting. I'm only exceeding the rating by 41 ftlbs. The block was only tested to 650hp in GM endurance testing and I'm 16.7 hp over that as well. Rules were made to broken. haha
Old 03-26-2010, 04:35 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Love that kind of talk.
Old 03-26-2010, 05:33 PM
The TKO has held up at power levels way above 600.
Old 03-26-2010, 06:05 PM
g356gear's Avatar
It was more from curiosity that I asked. Hurst drivelines rates them at 600 ft.lbs so I wanted to see if they have a good reliability at or over that mark.
Old 03-26-2010, 07:29 PM
I asked the same questions before I got mine and felt very comfortable exceeding that rating. Due to the 1st gear ratio, I do wish I had gone with a T56 (or the new Magnum T56 now available) FWIW.
Old 03-27-2010, 07:48 AM
gmorris gmorris is offline
I'm putting 700ft-lbs through my TKO with no issues so far.
Car looks awesome...I'm jealous of how light that aluminum block is.
Old 03-27-2010, 08:52 AM
mfain mfain is offline
I bought a TKO 600 Extreme from American Powertrain -- cryo-hardened gear sets and shafts. It is "rated" to 1000 hp. I haven't had a chance to abuse it yet, but when I do I will let you know how it does. Right now I'm on my way out to the Bull Ring to see how Todd does at the autocross.
Pappy
Old 03-27-2010, 09:54 AM
70rs's Avatar
70rs 70rs is offline
Congrats on getting to this point Todd! I am looking forward to hearing how the autocross goes. Nice work. And again, thanks for posting so much detail on how you are tuning and getting things dialed in.
Eric
Old 03-27-2010, 03:33 PM
Just got back from watching Todd at the SCCA autocross. Car looked great and sounded even better. Todd did a nice job on the course -- one of the top 2 or 3 cars. He should be really fast when he gets a slightly loose situation cleared up. He had his camera mounted so he should have good videos.
Pappy
Closed Thread
