Old 04-07-2010, 12:44 PM
GM Muscle's Avatar
Since 8 stacks have like "no" vacuum... (except a small signal for the MAP).. I ran a line to a breather can from the fuel pump block off plate. Drilled and tapped it for a -10.... then running two K&N breathers on the VCs. The can takes the bottom end pulses. Seems to work.
im running an ls based motor
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 04-07-2010, 12:51 PM
I submitted an "icon" with the "finger" to Scott awhile back ---- I wish he'd had included it in the selection to the right 'cause I'd so like to use it right now!
Old 04-07-2010, 01:05 PM
Forget what I said then, I have no idea on a LSX platform.
Old 04-07-2010, 02:13 PM
GM Muscle's Avatar
i know you love your fuel pump block off breather. dont worry, i wont steal your thunder!
Old 04-07-2010, 02:14 PM
GM Muscle's Avatar
haha.. well im concidering a pcv valve in the lifter valley plate with a nice baffle and just run the filters off the valve covers
