Old 04-12-2010, 08:44 AM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Those were good ones!
This weekend I used an etching primer on the metal. The local paint shop said to just get one light coat on to prevent rust forming. He said it was sort of a pre primer.
to clean the metal I used a metal wash first. It was a concentrated mix so I diluted it 50/50 with water. I sprayed it on and wiped it off with a clean rag. It took off any residue left on there and left me with clean metal as seen in the pics.
Of course, I cleaned as much as I could, but couldn't get every square inch. So, we'll see. It'll still be a while before this is all done.
I'll do the body work as needed then I can re apply paint/ primer as needed. I'll also use the Eastwood rust encapsulator paint in the inner sides as I've had good luck with that in the past.
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
