Old 04-22-2010, 08:28 PM
The WidowMaker's Avatar
its all about where the hole is located on the pedal. if you move your foot 6" and the pushrod moves 1" you have a 6:1. its just the ratio from the pivot point of the pedal to the mounting point of the pushrod and from the pivot point of the pedal to the foot pad on the pedal.
"The WidowMaker"
Old 04-22-2010, 09:13 PM
It's the length of the pedal arm and distance from the pivot point to the pushrod. If the distance from the pivot point to the pushrod hole gets to short, you sacrifice piston stroke.
I'm switching to a 1" bore master in my manual system. 7/8 is great in a street car but it's got it's drawback on the track.
I diagree Greg. There are advantages of power systems. It covers up brake pad knockback with a much larger piston. It's also better in a daily driver. How many factory cars have manual brakes?
Old 04-22-2010, 09:23 PM
There is a "newb" for brakes posting on here - in the brake section - that will show you "pedal ratio" and what it means etc. You'll have to search for the post -- if you don't want to do that - then just google "brake pedal ratio" and you should find all kinds of info.
Todd -- Power brakes are for pussies...
Covering up something is not the same as FIXING it.
Old 04-22-2010, 09:31 PM
I like manual brakes on the race track but they have their drawbacks. More pedal travel, more pedal pressure, more susceptable to knock back. If I was going to build a real touring car, it would have power or hydraboost. End of story. Maybe I'm just really bitter but I've never been thrilled anywhere but the Road Course.
Old 04-23-2010, 11:11 AM
Taman Taman is offline
Default pedal ratio
I understand what pedal ratio is. How is it adjustable? Does one need to drill another hole or is it already there? I agree about the power brakes. Automatics are the same unless your car never came with one.
Old 04-23-2010, 02:34 PM
Yes - you may have to drill another hole...
Old 04-22-2010, 09:35 PM
Not sure where you got that info -- but it's pure crappola....
If you can move your brake pedal 6" -- you'd have your foot on the FLOORBOARD....
Old 04-22-2010, 09:46 PM
Todd --
I know a good mechanic if you need one...
Old 04-23-2010, 12:14 PM
ccracin's Avatar
ccracin ccracin is offline
Floorboard, Hell if mine moves that far my shoe is melting on the header!
Chad
Instagram - @cctek
68 Chevy Pickup Project
