Old 05-03-2010, 04:47 PM
awr68's Avatar
awr68 awr68 is offline
Looks great!
Tony
'68 Camaro
Old 05-03-2010, 06:17 PM
65 347's Avatar
65 347 65 347 is offline
I think it was all stagged, I don't see any tools on the floor or mess anywhere.
Looks great! Good job getting done so quick.
Old 05-03-2010, 08:03 PM
XcYZ's Avatar
XcYZ XcYZ is offline
All that's left is an alignment (and set ride height). Got it running tonight and drove it around the block.
My LS7 69 Camaro
Old 05-03-2010, 08:09 PM
Can you fix that glare off the floor??
Old 05-03-2010, 08:10 PM
XcYZ's Avatar
LOL - You are one crazy Mo-Fo
Kudo's to you for doing a subframe swap in such a short period of time.
Okay so how many hours total in the swap ???
I'm guessing I have a solid 45 hours in it total since Friday afternoon. Quite a few of the little things took a lot longer than I expected, but isn't that typical. lol
Originally Posted by flash911 View Post
Snowmobile Dollies? There's an advantage to living in Minnesota right there...
That and free air conditioning in January.
Originally Posted by Rybar View Post
Im jealous of Scott's garage...
Yeah, but do you remember what a crap hole it was when I was building my car? lol It was truly a man cave. lol
I only see one thing out of place. I'd adjust that garage door chain.
That and the ceiling outlet and cover needs to be switched to grey. The car was on jackstands pretty close to it and I just didn't feel like using a screwdriver over my head anywhere near the car.
Originally Posted by BillyBobL71 View Post
Scott,
I'm curious, where the recessed area is in the subframe for the front oil drain plug, do you have enough room to remove/install?
Thanks,
Bill
No, you cannot use the front drain plug, it's noted in the DSE documentation. There's a provision in the frame for clearance though. You just use the side drain plug.
The countertop was FULL of tools and crap. All 30 feet of it.
My LS7 69 Camaro
Old 05-03-2010, 08:13 PM
XcYZ's Avatar
The floor held up awesome. I did some grinding, welding, steel wheels, dollies, floor jacks, jackstands... and there's only a few scuffs. I'm happy.
My LS7 69 Camaro
Old 05-03-2010, 08:17 PM
coolwelder62's Avatar
Scott did I see a run in the paint on the sub frame, or was it just the glair off the floor.Looks great . Did you do all this work in your garage in were the shot's taken in your kitchen.Scott
Old 05-03-2010, 08:37 PM
XcYZ's Avatar
Compare/contrast... Kinda cool I thought...
My LS7 69 Camaro
Old 05-03-2010, 09:30 PM
You could tell me you were putting either one in and I would be impressed with the up grade over stock. Very nice.
Old 05-03-2010, 10:12 PM
wrighton wrighton is offline
So Scott, first off very nice. what to start with first. Car?Garage?Subframe?Job well done?
I vote for all of the above.
I also am curious, anybody in line to purchase the other subframe?
Thanks for posting up the pictures.
Brian
