Old 05-13-2010, 02:45 PM
kennyd's Avatar
kennyd kennyd is offline
Default 2nd gen , ls1 , with factory front drive ?
we have a customer wanting a 2nd gen trans am with a ls1 and MUST use a factory pulley drive with AC . but from what i see we need to notch the front crossmember is that what everyone else does ?
changing the front drive is not a anwser or changing the front subframe .
Old 05-14-2010, 09:09 AM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Kenny- Currently working on setting up a 2nd gen with factory sub-frame to a L99 with factory drive.. It is a challenge but looking @ how I going to make it work... Listed is what I have discovered in our research..
Factory motor & trans sits 1 inch towards pass side measured from centerline of chassis
L99 drive sits alternator in lower position from LS1
L99 drive sits about 1 inch further away from block(like a truck drive)
LS1 oil pan gives the best clearence on sub-frame
Machining & fabricating our own Altnator & A/C brackets with motor mounts with trans support
Here is where we are @ this time..
Cris Gonzalez
Old 05-14-2010, 09:14 AM
Cris@JCG's Avatar
Here is a LS2 drive system that we made our own A/C brackets & dress up pulleys..
Cris Gonzalez
Old 05-24-2010, 05:53 PM
daytonayellaz daytonayellaz is offline
Nice job guys...putting a 6.2 in my 70 camaro pretty soon.
Old 05-24-2010, 06:10 PM
Cris@JCG's Avatar
Nice! Let me know if I can help with anything..
Cris Gonzalez
Old 05-24-2010, 07:19 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
subscribed! putting a 5.3l in an 80 Z28
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 05-25-2010, 10:00 PM
Im sure I will be hittin you up on this offer Thanks! LMK if you need anything as well....I have a couple LS motors for sale??
Old 05-26-2010, 07:47 AM
We have a bracket that will mount the compressor high on the passenger side in front of the cylinder head. Also working on a low mount SD7 compressor adapter bracket for the factory low mount position, but that is not finished yet. But the SD7 will make the notch much smaller then a 508 compressor notch
Frank Serafine
Old 05-26-2010, 12:28 PM
There are a few people that have put Fbody LT1s into their second gens and kept the AC. The compressors are in basically the same location as the LSx ones. The subframe just needs to be notched and it clears. This is only if you keep the engine in the same location relative to the bellhousing as the factory engine.
Old 06-09-2010, 04:55 AM
CreepinDeth's Avatar
CreepinDeth CreepinDeth is offline
I put a GTO LS1 in my 78 Camaro.
Couldn't get the AC unit to fit without notching the frame.
So I ousted it. Also the GTO alternator is bigger I was told and
it was hitting my pittman arm, so we had to relocate it.
There's places that sell AC relocation kits.
Go on Nastyz28 and research the High Tech Retrofits section.
I put up most of the info on the swap info sticky.
