Old 06-22-2010, 03:10 AM
A few things
(1) The (6) piston Dynapro offers ZERO mechanical advantage over the (4) piston Dyna lite. It is completely a bling factor.
(2) Prodigy Customs DOES have a Dynapro 12.19" rear kit with a special Dynapro caliper we use with smaller pistons specifically designed for rear application to maintain proper brake bias so you can have that better looking rear caliper
(3) We still have a few FREE polished / black master cylinder upgrades available
As advertised, (6) piston front / (4) piston rear WITH the free polished / black master is $2300, add $300 for rear (6) piston upgrade.
Our kits include
Kits include:
Wilwood Front and Rear Wilwood Kits
New front Hubs
3 pints Wilwood DOT 4 high temp Brake Fluid
Front Braided Brake Hoses
Prodigy Customs Rear Braided Brake Hose
E brake Cables for Internal E Brakes
FREE Wilwood polished or black master
Adjustable Proportioning Valve
We even include Safety Wire and Safety Wire Pliers for proper 2 piece rotor assembly
See ad here:
https://lateral-g.net/forums/show...hlight=wilwood
Base Total Car G Machine Brake Package with 12.2" F (4) piston Dynalite / 12.2" R (4) piston Dynalite kit With Standard Black Calipers / Standard Smooth Rotors ONLY $1800
Frank Serafine
