Old 06-30-2010, 11:19 AM
Jr's Avatar
Jr Jr is offline
Default Factory LS harness?
Hello,
I didn't know if this should go in the electrical or EFI section...
I plan on dropping in a 5.3LS motor in my 70 shortbed pickup, but I have a question about the factory harness:
I was wondering why I need to have the factory harness modified? Why cant I just use it the way it is? I will delete vats and other stuff in the ecu that I don't need.
Any help would be appreciated.
David
Old 06-30-2010, 11:26 AM
camcojb camcojb is online now
Originally Posted by DJW32 View Post
Hello,
David
you can use the stock harness as long as you disable vats and things you won't be using. Most people swap for a couple of reasons.
1. To get a new harness with just what you need, cleaner install.
2. Get a custom length harness. Most of the factory computers are under the hood and most aftermarket installs want to hide the computer inside the car. In that case the factory harnesses usually are not long enough to reach.
Old 07-01-2010, 09:58 AM
catz's Avatar
catz catz is offline
Hi David, I bought a book on ebay, custom standalone wiring harness for ls1 , very helpful has all the pinouts for the years 29.00 well worth it good luck Bob
