Old 01-04-2005, 08:48 AM
XcYZ's Avatar
XcYZ XcYZ is offline
True, you may not need it, but it does work awesome. Adding Hydroboost to your Wilwoods would be like... well... adding twin turbos to a 427 CID LS1.
My LS7 69 Camaro
Old 01-04-2005, 09:30 AM
Musclerodz's Avatar
I will be running LS1 brakes with Hydroboost. I couldn't see paying for a name for entry level brakes, and I can't afford the good stuff right now. There is more important stuff to buy.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-04-2005, 08:52 PM
Blown353 Blown353 is offline
Basic Baer/PBR setup here. What really makes it work though is the hydroboost from Paul. Brakes were OK before, but are now stupid-good with the hydroboost.
Howard-- at the risk of stating the obvious (and please don't be offended if I do) Wilwood is correct. A hydroboost becomes less important as you move to a caliper with more piston area (i.e. a 6 piston caliper) as the greater piston area requires less line pressure to generate adequate clamping power. However, for setups with lesser piston area (i.e. PBR calipers) the only option to make them bite harder is to increase the line pressure, which is where the hydroboost comes in-- you can get mega line pressure out of a larger bore MC so you still maintain reasonable pedal travel. Otherwise to generate those line pressures you are looking at a small bore MC with a large pedal ratio, which means uber-long pedal travel.
You can most definately run a hydroboost with large piston area brakes, but it really won't be needed if piston area, MC bore size, and pedal ratio are properly matched. Running a hydroboost with large piston area brakes will makes TONS of braking power available, however at the expense of reduced pedal "feel." It also means you can run a larger bore MC and cut down on pedal travel if that interests you. There is nothing like the feedback offered by a PROPERLY designed manual brake system, but the hydroboost gives good feedback too, especially if it's a tweaked and bluprinted unit; far better feedback than a vacuum booster IMO.
Personally, I'm waiting for Jody to post pics of his seatbelt-bruised chest after he tries his Hydroboost/Alcon combo for the first time.
1969 Chevelle
Old 01-16-2005, 01:21 PM
Y-TRY Y-TRY is offline
You should REALLY check these guys out for a more affordable option:
Touring-Classics
Old 04-12-2005, 10:06 AM
T Bell T Bell is offline
Wow that is a great setup. I hate that the C5 kit doesn't fit the TTII and I'd have to get the hybrid setup with a thinner rotor. I must change my sig.
1972 Nova 355, 4 spd, rusty but something to drive.
1972 Pro-touring Cutlass S in the works....still
Old 04-12-2005, 11:09 AM
PhaseShift's Avatar
PhaseShift PhaseShift is offline
I am a little suprized that nobody mentioned AP Racing for the calipers. If I were to upgrade, it would likely be to AP brakes.
http://www.apracing.com/
PhaseShift
rscamaro.com
Old 04-12-2005, 11:51 AM
BC69's Avatar
BC69 BC69 is offline
The rarest brake setup on the site!!! 4 WHEEL DRUMS BABY!! I dont even know what baers would feel like, and its not like I drive much or fast, I am like an old lady when I drive the Camaro, so it works for me.
Tim
In memory of those gone before us
In gratitude for those who care.
Old 04-12-2005, 12:18 PM
spaztikatik spaztikatik is offline
It's not like I could tell you how my brakes perform yet, considering they've been in boxes for the past 2 months, but I got myself the Baer GT+ system with 14 inch front rotors and I'm using their touring 12" disc system on the rear with PBR calipers all around.
I liked the GT+ system versus the track system because of the extra rotor surface area (275's up front will use the 14 inch rotor nicely) plus it uses the new C5 caliper versus the old C4 caliper, given the C4 caliper is still amazing as well for resto-mods.
Oh yeah, plus I got my kit for DIRTTTTT cheap
Old 04-12-2005, 12:25 PM
USAZR1's Avatar
USAZR1 USAZR1 is offline
I'm running Baer's 13" Track front and 12" Touring rear kits with two-piece Eradispeed rotors on my 69 El Camino. We didn't use the m/c Baer supplied but I'll be darned if I can remember what unit we ended up with. Whatever it is,the brakes are very strong and linear with a firm pedal.
However,I'm thinking about going for Baer's new six piston caliper set-up.
Clint Hooper
Clint's 70 El Camino restomod Sold
Clint's 69 Elky Protourer Sold
Old 04-12-2005, 02:21 PM
rwhite692's Avatar
C5 corvette front and rear (LS1), + Hydroboost.
IMHO...what I tell guys who think that their original brakes are "good enough" is to consider that, when you are surrounded by modern vehicles out on the roads, you'd better be sure you have some damn good brakes, because they all do, when compared to the stock 1950's technology on 60's musclecars.
Or...just make sure there is never anyone driving a modern car out in front of you...
Project update thread here:
My Lateral-G Page
My Shop Build:
