Old 07-20-2010, 06:52 AM
Apogee Apogee is offline
Originally Posted by CreepinDeth View Post
...So let me make sure I understand this.
You crack the 2 fittings while pressing the plunger in on the MC.....to get the air out.
Then before releasing the plunger you tighten the 2 plugs ???
....or did I misunderstand that ??
That's about right, except I just do one fitting at a time since I'm usually juggling a rag and trying not to get brake fluid everywhere. Have someone press and hold the pedal while you crack open and then close one fitting at a time and repeat until you're satisfied. I've found that 1-2 times per fitting seems to be plenty most installations.
Tobin
KORE3
www.kore3.com
Old 07-20-2010, 08:02 AM
I bench bleed the M/C on the bench rather than on the car. It's hard to get all the air out of the M/C sometimes. I use a large phillips screwdriver as the push tool... and that way I can really bottom the plunger. I have a set of lines I use that hook up to the outlets and return to the M/C reservoir and I can SEE that there is not a single bubble left before the install. I cap it -- and leave the lines on - get it bolted up - toweled up - and swap the lines over.
One other thing that is a mistake I've found several times trying to help someone with "brake issues".... Not every M/C is the same line configuration - i.e., some M/C's run the front reservoir to the fronts and some run the front reservoir to the rear. The way I've found to check for this is while I'm bench bleeding it - I plunge slowly while looking for the fluid flow FIRST in which bowl of the reservoir - that reservoir should be to the fronts. If you do this a couple of times - you'll see what I'm talking about - you'll see fluid just a nano second before in one bowl or the other. That wouldn't give you a mushy pedal - I'm just adding this since you're using parts you may or may not be familiar with...
If you bench bled the M/C - and went thru a gallon of fluid - I say you've got a bad M/C and should probably just get a new one.
Old 07-20-2010, 09:01 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
just going to throw this out there since i know first hand this can happen. do you have the rotors bolted on or the wheels bolted on? it may sound like it shouldn't matter but this just happened to me the other day and then i remembered i didn't have the rotors bolted onto the hub. but i blead the system then had a soft pedal. bolted the wheels back on and have nice hard pedal. the rotor being able to move side to side even though its just a little bit is enough to push the pistons back and give you problems
Old 07-20-2010, 10:31 AM
Just one last thought on this problem... I think we'd all ASSume that you know how to bleed brakes.... which is the furthest away first -- so passenger rear first - then driver rear - then passenger front - then driver front....
Old 07-20-2010, 02:09 PM
PRRC PRRC is offline
I would say that 1 problem with this set up your running is the 1/4 line to rear calipers. It's just to large of a diameter for a disc. set up.
www.paradise-road.com
Old 07-20-2010, 04:02 PM
Expansion due to pressure within a brake system is referred to as system compliance. All components have some compliance including calipers, hoses, hard lines, master cylinders, etc, however the goal is to typically minimize it as much as possible for the most responsive braking system possible. When comparing various components, rubber brake hoses are by far the largest contributors to system compliance, so if you have rubber brake hoses, it doesn't really matter what the other components are since their contribution is negligible.
If you want to look at the difference between 3/16" and 1/4" brake tubing, it's just a matter of comparing the hoop stresses and associated strain values. Assuming the wall thicknesses are the same (typically .028") and so is the tubing material, the 1/4" tube will expand 45% more than the 3/16" tubing if my math is correct. Considering how little the 3/16" tubing expands under pressure, 45% more than that is still a basically negligible IMHO.
On most street cars, I can't tell the difference at the pedal if a car has 3/16" or 1/4" tubing. If you had a car set up for track use that was right on the edge of locking up the rear tires at threshold braking and you made the swap from 1/4" to 3/16", I would hazard a guess that you might notice the difference, but nothing that a small crank on the ajdustable proporioning valve wouldn't solve. That said, if you were plumbing a car from scratch, I would run all 3/16" since less compliance is ultimately a good thing, even if you are splitting hairs.
Tobin
KORE3
www.kore3.com
Old 07-20-2010, 10:27 PM
CreepinDeth's Avatar
CreepinDeth CreepinDeth is offline
Well , my new Raybestos premium NEW 79 Vette master arrived today.
So tomorrow I bleed it Tobin's method on the vise. Front angled down.....and this one came with plugs.
The 2 reman's came with tubes for the OTHER MC bleeding method. So that's a good start.
I did it both with the rear + front wheels off while bleeding AND did it with the wheels on.
Yes sir. I did my research first. I followed that procedure EACH and EVERY time.
EXACTLY word for word how I did both my Vette masters.
Except I didn't plug them going from the vise to the install.
1st one went good on the 78 z28, front C5 brakes, rear stock drums, 1st time worked.
2nd one not so good on my 442, front stock disc, rear Baer disc, total TARFU mush pedal.....lol
79 Vette masters are equal size reservoirs.
Several guys on Nastyz28 have used this with success this way too.
So I'm not guinea piggin it.
Old 07-22-2010, 11:50 AM
Hydratech®'s Avatar
Supporting Manufacturer
HydratechBraking.com
Default Port Plug Diagnostics
If all else fails, you may have to get into port plug diagnostics. Even though this article is written for hydroboost applications, the basics still apply to a manual or vac assist brake package: http://hydratechbraking.com/Hydratech/braketech1.html
For instance, you could plug the ports at the rear axle flex hose, obtain a good pedal, THEN connect one rear caliper at a time, bleed it out and see what you've got. Since this axle was handled / transported, it strikes me that you may even be fighting an ever so slightly tweaked caliper mount bracket (that could've been thumped while wrestling the axle around).
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
Old 07-22-2010, 04:01 PM
Well it wasn't the master!!!!
So instead of taking the Repro Vette master off and plugging it and checking to see if it was bled properly,
I decided to just ASSUME it was bad, paint the new Raybestos one, plug it, bleed it, install it.
Then for the hell of it I threw the repro MC on the Vice and plugged it.
Bench bled it , plugged, with the screwdriver and ZERO bubbles came out and it locked up before 1/8".
I tried 15x and it's definitely bled properly. So now I really have no idea WTF it could be if it wasn't the master.
Tobin, you're saying air in the system, but I really bled the crap out of it several times. It's aggravating the ****
out of me. I'm wondering if I really do need a smaller bore MC but then other guys are running rear discs too with
this MC but it's possible the pistons are different. I"ve got power brakes, I thought it would be cake......nope!!!
IF that was a factor in the hydraulic system, I'd see some fluid leaking somewhere for the mushy pedal though no ??
I don't see any fluid leaking.
Old 07-22-2010, 04:35 PM
Hydratech®'s Avatar
Default Making progress
Great! Now you can definitely rule out the MC as the culprit, and can continue moving your diagnostics further downstream in the brake system.
FYI - A bent caliper support bracket would be not readily visible to the untrained eye, and could cause the caliper to deflect crooked / cocked ever so slightly off plane in relation to the brake rotor. Then when you try to apply pressure to the caliper, you are "wasting" all of the fluid volume going to the caliper while the caliper straightens itself out by trying to clamp straight on the rotor. Take a close look at the calipers, pads, rotors to see if you spot anything ever so slightly "off" angle. Take a bright light and see if there is any air gap at say the front of the pads, yet no air gap at the rear of the pads (or on any other plane in relation to the rotor).
One glaring question - are the bleeder screws at the tops of the calipers? I just can't tell you how many times I have seen the calipers installed backwards (left caliper swapped with the right caliper, finding bleeder screws at the bottom instead of the top. You could run a tanker truck of fluid through the brake system and never get the air out if this is by chance the case.
Humor me - run up to the auto parts store and get some 3/16 brake line plugs in the brass section, then plug the rear axle flex hose where the steel brake lines go out to the calipers. Fill the MC up with fluid, leave the two ports open on the end of the brake flex hose, then wait for the fluid to start dripping steadily out of the ports on the rear axle brake flex hose (gravity bleeding discussed in our online article that I put a link up to in my previous post). Once the fluid is dripping steadily, then go ahead and pop the brake line port plugs into the flex hose and snug them up. If you then find a solid brake pedal, you have ruled out everything else in the vehicle's brake system except for the rear disc brakes (where this whole problem started). You could then connect one rear caliper at a time to the rear axle flex hose and bleed it out and see what happens. If everything goes bad again with say the driver's caliper hooked up (or vice a versa), then you can focus your attention to the specific area and then likely nail the problem.
Pneumatic testing: While potentially very messy and 'dangerous' to painted surfaces, you could also take a rubber tipped blow gun and actuate the brakes by hitting the brake lines (at the MC) with compressed air (use a large towel to catch any possible brake fluid). I know we are trying to rid the brake system of air, but push come to shove sometimes you do what you gotta do to figure out what in the heck is going on. With the compressed air, you can watch the brakes engage and release when you hit them with pressure, and might just spot something.
