Old 08-14-2010, 03:31 PM
prostreet69cama's Avatar
prostreet69cama prostreet69cama is offline
We used the Mikes Custom Car rear seat. It is a little pricey. Also had to add about a 1" of foam on each side but overall it looks real good.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/albums/j...treet69camaro/
Old 08-14-2010, 07:27 PM
jliddle jliddle is offline
You are running a complete Marquez interior right?
Old 08-14-2010, 07:48 PM
g356gear's Avatar
g356gear g356gear is offline
Do the rear "door" panels need to be modified as well?
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 08-15-2010, 08:17 AM
Z06vette's Avatar
Z06vette Z06vette is offline
If using the DSE tubs, the covertible seat is still too long, and the rear panels with the arm rests/ash trays are not deep enough. The flat rear interior panels will work fine, either std or deluxe. I am about to start cutting the springs in my rear seat to fit. Not realy sure what the best way to go about it is, but just going to lay the seat frames in there & start marking/cutting i guess. Maybe someone that has done this already wil chime in on the process.
Old 08-15-2010, 12:18 PM
Scott,
We were going to use the factory seat but wanted the front and back seats to match.
I would do what you were saying. Lay the top part in and cut the frame as needed on each side and then weld in some round stock to stiffen it.
Then remove the top part and do the same to the bottom section.
Mike
Old 08-15-2010, 12:14 PM
Yes except for the package tray and console. The interior guy made a custom console and package tray. The front seats are 99-02 firebird seats.
Mike
