Old 06-24-2010, 03:55 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
Originally Posted by CraigMorrison View Post
Are you guys asking about a four link or triangulated 4-bar? Are you doing an install on a stock chassis / unibody or building your own thing? Or are you just looking for the optimum angles and trying to get close?
I'm building my own Tri-4 for my 69 Camaro 12 bolt and will use your kit if it will work for me. Going to cut into the floor a little bit for the upper links to help the geometry. Optimum angles and link lengths would be great to know.
Erik
Old 09-18-2010, 08:36 PM
millerman340's Avatar
millerman340 millerman340 is offline
How well does the 3 link handle 1/4 mile abuse?
Old 09-22-2010, 12:48 PM
Silver69Camaro Silver69Camaro is offline
Erik
Eric,
Sorry for the late reply (I'm not on here too often), but the lower bar should be at 0 degrees, while the upper is 4 to six degrees down. You'll probably find that packaging restraints will determine where it will be.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 09-22-2010, 12:50 PM
It depends on tires, basically. I wouldn't use it with some 31x18.50's, but should be just fine with street-sized drag radials, provided you aren't running 8's in the 1/4 mile.
Matt Jones
Mechanical Engineer
