Old 09-23-2010, 01:38 PM
awr68's Avatar
awr68 awr68 is offline
How about This?
Tony
'68 Camaro
Old 09-23-2010, 03:11 PM
street3285 street3285 is offline
That would be perfect. To be honest, I was hoping to find something used off a 90's truck, and use either that P/S and alternator or re-use my own.
If I can't, that is definitely a good way to go. Thanks guys.
Travis
Old 09-27-2014, 09:13 PM
JKnight JKnight is offline
Does anyone sell a kit that includes just the brackets, hardware and pulleys? I have no need to replace the water pump, alternator or Type II PS pump, bud I'd like to convert to a serpentine system.
I'm basically trying to avoid the hassle of a junk yard run and dealing with fitment issues.
Old 10-03-2014, 03:46 PM
130fe 130fe is offline
Post
If you are trying to use the GM style factory serpentine setup, then I believe you have to change the water pump (reverse rotation). I don't know if the Type II PS pump you have would fit either.
I have used the 88-92 F-body serpentine setup on an old SBC I had and it worked great. You can also look for 90-95 5.0 or 5.7 truck stuff.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 10-04-2014, 10:47 PM
Sure, It looks like the AFR heads I have do include the accessory mounting holes so that may improve the odds of a factory style system working. I'm not in any hurry, as the existing v-belt system works ok.
Chris, I hear ya on the reverse rotation water pump, I know that may be a necessary change depending on the system I end up using. Seems likely given the typical wrap arrangement. With the PS pump I assumed (there's that dangerous word) it would be ok with a pulley swap since it's essentially a modern style part. Plus, the location and wrap of the V setup seems the same as most serp systems I've seen, I believe...
I'm not necessarily aiming for a gm setup, but if that's the only budget approach that works well and allows me to re-use some parts, then so be it.
Old 10-05-2014, 07:28 AM
Thumbs up
One more thing about the GM water pump (either 88-92 car or 90-95 truck), if you go that way. The truck pump has provisions for a heater hose (similiar to one on a SBC), the car one does not (the heater hose connects to the radiator on the TPI cars). I believe the spacing is the same on both. The TPI corvette has a another serp option but they are probably alot harder to find and I believe the water pump spacing is different.
Chris
1968 Camaro SS
LS3/T56
