Old 10-05-2010, 04:57 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Should I cut this metal out?
I actually have two questions, the first, as the title says, I'm wondering if I should cut this metal out or if it will be okay. I found a few spot on the windshield channel where it is pitting like this. There are a couple spots that are obvious and need to be cut out. Is there anything that I can use to replace the stock mounting tabs for the chrome trim if I replace a bunch of the metal?
I'm going to cut out this part, but that's the tab I'm talking about.
This is what the metal looks like where I'm wondering about.
I'm also wondering about some rust in the drip rails. I don't plan on smoothing them or I wouldn't be too worried, but I'm wondering what I can do about the bit of rust that's at the bottom since I plan on leaving them. I will be putting sealer back in.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 10-05-2010, 05:30 PM
IndyNova's Avatar
IndyNova IndyNova is offline
I believe they make screws that take the place of those moulding studs, as far as the drip rails, If your going to smooth them, I wouldn't worry too much about it, that's about how mine look, but I've got rust issues on the dash and firewall area.
Old 10-05-2010, 07:44 PM
NsaneHotrodz's Avatar
NsaneHotrodz NsaneHotrodz is offline
When in doubt cut it out! lol. Seriously if you don't cut it out you'll be sorry.
www.nsanehotrodz.com
Dewayne Morgan
[email protected]
Old 10-05-2010, 08:30 PM
elitecustombody's Avatar
^ I agree
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 10-06-2010, 08:37 AM
PRRC PRRC is offline
Yes, I would remove any rusted arears. As for the trim clip studs. You can use a stud welder to replace them. Just mark the location on the roof panel so you will know were they were in relation to the window channel.
Tim
www.paradise-road.com
Old 10-06-2010, 06:03 PM
scherp69's Avatar
Thanks for all the replies guys. My plan was to cut out the ugly metal, but just thought I'd check and see if everyone agreed. As for the tabs, I will likely use these http://cgi.ebay.com/ebaymotors/67-68...#ht_806wt_1167 as I don't plan on buying a new welder for one car worth of tabs.
Mike
New Gen Splitters
LS3 and TKO600
Old 10-07-2010, 04:28 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Yeah, rust holes should be fixed.
Those screw clips work fine. Get a few extra, because they're easy to strip.
