Old 10-16-2010, 08:23 AM
pacificustoms's Avatar
pacificustoms pacificustoms is offline
Rear frame all finished and wheel tubs done.
Painted the entire underside in a light texture coating.
There's a nice contrast between the two frame and body now.
Robbie Azevedo
Pacific Coast Customs
Become a fan on facebook for weekly updates and giveaways: http://www.facebook.com/pacificcoastcustoms
Old 10-16-2010, 08:27 AM
Gas tank built from scratch with all of the evap stuff from the original tank. We decided to keep everything GM put in the car, that way it's as close to "stock" as possible. We even re-used all of the plastic lines by heating them slightly, bending them and letting them rest in their new form. If you have a lot of patients, it isn't that difficult to do.
Robbie Azevedo
Old 10-16-2010, 08:31 AM
Rear pieces back from powdercoat.
Gas tank mounted...
Robbie Azevedo
Old 10-16-2010, 08:41 AM
Lots of clean work going into this thing.
What are you using for bearings in the shock rocker arms?
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Very nice Robbie. Should be a fun project when complete.
Old 10-16-2010, 08:57 AM
The shock rockers arms are using bronze oilite bushings from McMaster.
Robbie Azevedo
Old 10-16-2010, 09:02 AM
The interior cut up. These were the worse cuts in the whole project for me. I dreaded cutting all of the interior panels and plastic. We've formed a speaker box that comes off of each side and is open down the middle. The speaker box covers up the wheel tub and fits up snug to the factory plastic.
Machined a piece to run all of the wiring through now. You can see the huge hole that was used before. We filled the hole in because we needed the clearance for the tire. We needed a really large hole to fit all of the large plastic plugs through that plug into the fuse box.
Robbie Azevedo
Old 10-16-2010, 01:33 PM
bentfab's Avatar
bentfab bentfab is offline
Looks good ! Very simple and clean. When I say simple I know it aint easy.
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 10-16-2010, 02:58 PM
BritishGreen68 BritishGreen68 is offline
This build is in Street trucks right? I love that mag... you are doing some nice fab work...
Chris
Under construction-British Green 68 Camaro-
Old 10-16-2010, 05:20 PM
T-Type T-Type is offline
great work! where will it be parked at sema? i'd love to get an upclose look at it.
