Old 10-19-2010, 02:27 PM
6spdcamaro 6spdcamaro is offline
Originally Posted by marks914 View Post
We are going to run the extra gauges once we get a feel for what folks need (oil temp, boost, arf, etc..)
The 2-1/16" gauges feature peak hi/low warning and recall.
I'm going to be buying a set of these in a few months as money comes in. The warning lights are an awesome feature.
The only extra gauge I would need (in addition to the normal 6) is oil temp.
Ken
Old 10-19-2010, 06:42 PM
jmac jmac is offline
lookin' good!! Can't wait to see your 3 in 1's!!
My 1967 Camaro
Old 10-20-2010, 04:46 AM
marks914's Avatar
marks914 marks914 is offline
Regular User
Yes we will have:
Oil temp
Nitrous pressure
vac/boost
trans temp
air-fuel ratio, narrow and wideband
fuel pressure 100 psi
Im probably missing something, but pretty much everything will be available
Mark
www.newvintageusa.com
Old 10-20-2010, 08:23 AM
1Bad68Cat 1Bad68Cat is offline
Is it possible to add turn signal indicators, high beam indicator, and check engine light in the face of the speedo/tach?
Old 10-20-2010, 09:10 AM
marks914's Avatar
Regular User
We might be able to install a couple of LEDs on the dial, but not the way we do them on our Woodward gauges, just not much room in there.
Mark
A good way to to that is with our indicator gauges:
or with our indicator panels:
Old 10-28-2010, 04:20 AM
marks914's Avatar
Regular User
Just an update, we now also have 2-1/16" stepper motor gauges with the following functions:
Vac/boost
Oil Temp
Trans Temp
A/F ratio wide and narrow band
Nitrous pressure
Fuel pressure
EGT
We have them in the redline and 69 series
redlines:
http://www.newvintageusa.com/redline.html
69 Series:
http://www.newvintageusa.com/1969.html
Working on the 5" gauges, but the 3-1s are kind of taking most of our time.
Mark
