Old 12-02-2010, 10:32 AM
Musclerodz's Avatar
Originally Posted by awr68 View Post
Looking good Chris!
Blake, I have an 18x9 with IIRC a 5.625" BS...hope it all works out! Pete hasn't said anything about clearance issues...but it isn't aligned either. I was working off the trusty 8" with 5" BS when I ordered the wheels...as long as the new track width is the same as stock I should be golden! Your thoughs?
I think your gonna have rub issues when you get the car down to ride height. I had issues with 5.5 bs, but I had planned to cut the fender anyways.
Mike Redpath
Musclerodz & Customz
facebook page
Old 12-02-2010, 11:32 AM
bdahlg68's Avatar
bdahlg68 bdahlg68 is offline
This thread is swaying me towards the Speedtech rear.
Frank / Blake - any chance to get a quote for a complete torque tube with 9" rear setup shipped to 48187? vehicle is a 1968 Firebird.
Thanks!
Old 12-02-2010, 11:45 AM
awr68's Avatar
awr68 awr68 is offline
Hope not! But if I have to rehoop the front wheels then that's what it takes! Thaks God for 3-piece wheels!!
I just drew it out on paper and the wheel's front lip will be outward 3/8" more than my 8" w/ 5" bs...which those fit no problem. However that was with the stock frame and a 245 tire. Time will tell!
I'm pretty sure a 9" wheel w/ 6" bs would hit on a OE frame...there must be quite a bit more clearance built into the ST frame?
Tony
'68 Camaro
Old 12-02-2010, 12:06 PM
James OLC's Avatar
I know that a 9" wheel with 6.375" of backspacing will just brush an OE frame at full lock when the steering stops are not adjusted. With the stops adjusted on my SpeedTech LCAs there is no issue and only a minimal loss or turning radius.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 12-02-2010, 12:32 PM
wrighton wrighton is offline
Good info guys , I have a 69 camaro
Old 12-03-2010, 09:12 AM
youthpastor's Avatar
finished the suspension last night and wanted to show the clearance of the Speedtech frame with a 18x9 on a 275
you can see that the arms and sway bar are designed for clearance
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 12-03-2010, 10:11 AM
awr68's Avatar
Great shots Chris!
Did you test fit these wheels/tires with the front sheet metal installed? I have 3/8" less bs than you. Obviously frame clearance won't be an issue...but the fender might be a problem. Just wondering what the clearance was like on yours.
Tony
'68 Camaro
Old 12-03-2010, 10:57 AM
Great shots Chris!
wheels just showed up...but Roger said it should be more than enough
[SIGPIC][/SIGPIC]
Old 12-03-2010, 11:52 AM
Lateral-g Moderator
Would a 10 inch tire fit also?
Old 12-03-2010, 12:06 PM
Blake Foster's Avatar
yes on a 69 for sure 10 with a 6.75 to 7" BS
Blake Foster
www.speedtechperformance.com
