Old 01-30-2011, 07:09 AM
wmhjr wmhjr is offline
You don't need a return line with a non bypass regulator. I would pick up a deadhead regulator like http://www.summitracing.com/parts/AEI-13205/ . The 13205 gives you adjustability. If your pump isn't causing any issue other than the pressure being slightly high then this would fix you up.
