Old 03-01-2011, 05:27 PM
ccracin's Avatar
ccracin ccracin is offline
Originally Posted by 6D9 View Post
I wonder if they plan to make a EZ-EFI that would support 650+ HP??
You can probably get to 650 with one TB. Our engine in the video made 614 at only 43psi fuel pressure. You can go up from there. I think much past 650 and air will be a problem. The dual TB's are in order.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 03-02-2011, 04:14 PM
6D9 6D9 is offline
Thanks Chad for the info!
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
