Old 03-18-2011, 09:44 PM
ccracin's Avatar
ccracin ccracin is offline
Default Another Project Done, Almost!
We have been working on getting seats mounted so that we can get to work mounting the brake pedal, steering column, and a/c unit. Since this is a truck and there is very, very limited space to put things, we decided to try and maximize the room we do have. We decided that under the seats was some space that could be used for things like the EZ EFI and EZ TCU computers as well as maybe the audio amplifier. There are so many electronic items we need all the space we can get. However, I was not about to have to take the seats in and out to get to this stuff. The Corbeau seats we are using have an adjustable back so here is what we came up with.
I think it's going to work out just fine. I just need to add some braces as there is a very slight amount of lateral movement in the front of the seat where the bear claws latch. I will also add a spring cylinder to hold the seat up and a linkage to trip both latches at once.
Pay no attention to that weld seam in the floor above. We didn't do that and it will get fixed!
Here's the real payoff!
This may not seem like much, but this is the first time he has been able to do this since the truck got torn down.
All comments are welcome as always!
Chad
Instagram - @cctek
68 Chevy Pickup Project
