Old 04-15-2011, 11:30 AM
Ringbrothers Ringbrothers is offline
Default Ringbrothers Touch Starter System
This has to be one of the coolest products we have! The first ever touch start button. Touch not push. The button is touch sensitive with an interactive LED display.
Direct replacement for standard keyed ignitions.
Simulates five positions of keyed ignition: Off, Accessory, On, Crank and Run
All required wiring and connectors are included and no external relays required.
Made in the USA
Price: $650
Check out our website for more information
Old 04-15-2011, 12:51 PM
pokey64's Avatar
pokey64 pokey64 is offline
Have any video of starting a car with it?
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 04-16-2011, 07:35 PM
Bakaruda's Avatar
Bakaruda Bakaruda is offline
Definitely need more information please.
Old 04-17-2011, 04:55 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
Will this work with ISIS?
Erik
69 Camaro
Old 04-18-2011, 07:59 AM
More details:
FIRST TOUCH: Simulates Accessory position turning on only consumers such as your radio to conserve energy and save sensitive components such as heated 02 sensors and engine computers. (which may suffer from being turned on unnecessarily)
SECOND TOUCH: Simulates On position which is typically connected to power windows, engine computer, gauges etc.
THIRD TOUCH: Simulates Off position.
• A push on the brake and momentary press on the switch engages the starter. Starter is automatically disengaged once “Ignitor” senses the engine running. A convenience found in many modern luxury vehicles.
• Another push at any time returns the ignition to an off state. It’s just that easy!
• Interactive built in led display allows for visual conformation of simulated key position. A theft deterrent pulsing red light when vehicle is off is included.
• Will accept input from any momentary switch, including popular O.E.M. ignition switches! Corvette and Viper switches are in-stock and ready to use. We can also modify any other switch you may be considering for your vehicle to work with “Ignitor.”
• Tach-less input allows for easy installation with any type engine. Built-in circuitry monitors state of engine to determine when it is running.
• Optional security enable input allows for interface with security devices allowing only authorized users access to your vehicle’s ignition.
• Available retained accessory option keeps accessories live for ten minutes after ignition is turned off, or until door is opened.
Old 04-19-2011, 12:09 PM
Yes, it will work with ISIS. But, polarity will have to be switched unless the node input porgramming can be changed to accept +12 volts. The easiest way to do this is with relays... In other words, ISIS needs a ground input trigger and our stuff outputs positive.
Let me know if you need more detail.
Thank you,
Staci
Old 04-19-2011, 03:47 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Will you throw in a set of floaties if I buy this Staci??
Autokraft
Old 04-19-2011, 07:18 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
I want this! May be a stupid question, but will it work with manual cars. I know you have to depress the brake.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 05-19-2011, 11:45 AM
Better pictures
Old 06-21-2011, 10:04 AM
Just wanted to let everyone know that we accidentally used a trademarked name for our start system. We immediately pulled the name and are trying to come up with something new. Any ideas?
