Old 05-30-2011, 11:07 PM
Pasquale Pasquale is offline
I'm not familiar with the diameters that 295's come in but I like to run a 26" diameter tire. 315/30's and 275/40's both come in near to that diameter in 17's and 18" wheels. 295 is a good size to shoot for up front but IMO you want to be sure the rear tire is the same or close to the same diameter.
Yes, I agree with you that the wheel diameter should be close to the same, but if I run the width of 295 in the back, in your opinion what would be the widest width I should run in the front. Is 275 in the front too close to 295 in the back? Should I go narrower than 275?
Old 05-31-2011, 08:29 AM
Track Junky's Avatar
The best combination for practicality would be the same size front and rear. This way you could rotate tires front to back.
I wouldn't go narrower than a 275 up front both for looks and mostly for performance reasons.
Take a look at tire width's in 295. I would bet that a 295 is only 1/2" wider than a 275. I dont think that going with a 295 is worth it.
Gaetano Cosentino
