Old 07-21-2011, 10:11 AM
J2SpeedandCustom J2SpeedandCustom is offline
If the factory put lead there you need to put it back! "Any" type of filler will show after the car has been driven and set out in the sun. Do it correctly and you'll never have a problem.
Jeff Allen
J2 Speed and Custom
Old 07-21-2011, 12:51 PM
70rs's Avatar
70rs 70rs is offline
I dont know what was in mine to begin with. It was a vinyl roof car from the factory. When I got it, the roof to quarter seam had been cut out and attempted at a patch. Now I get to remove the crap the PO did and make it right.
I have seen MANY second gens with cracks there. I want to be sure it never happens to me.
Just say no to crack!
Eric
Old 07-21-2011, 07:00 PM
Rick D's Avatar
Rick D Rick D is offline
Eric PM Scott (protour73) He should have pictures of how I did his 73 Camaro 4 years ago and still looks as good as day one. I think the pictures that i have are on a different computer.
Rick
Old 07-22-2011, 10:40 AM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
I would like to see photo's also.
Eric, what are you planning on usinig?
Ron
1969 Firebird, 4-speed Coupe
Old 07-22-2011, 10:45 AM
70rs's Avatar
Thanks Rick
I'm not sure yet Ron.
But to answer your question on lead, yeah it aint healthy for ya.
Eric
Old 07-22-2011, 11:00 AM
Right now I'm planning on going the lead route myself. It is "extra" so it might slip out of the plan for money reasons but like some of you, I think that is the "right" way to do it. Plenty of shops use other, more common fillers(fiber enforced filler, AllMetal, regular filler) and methods though without issue based on what I've found out. I think as long as whatever the choice if it is done well by a skilled individual, it will last.
They don't really use "lead" though due to health and environmental issues. It's some other similar "body solder" product. So some might argue "but it still isn't 'lead'"
I'll update with pics once the time comes.
John
'71 Nova (Build thread)
FFR Roadster
Old 07-22-2011, 10:42 AM
Ron Fox's Avatar
Are there any problems associated with working with lead? Is it easy to put on and work? Is it somewhat harmful while using it or after it has been applied?
Ron
Old 08-02-2011, 10:07 AM
Ron if you don't want to work with lead you can call "Johnson Mfg" - http://www.johnsonmfg.com/ they have a whole line of lead free solders that will work. You have to use a different tinning and the melting temp is a closer tolerance than lead. But you can sand / DA with fear of those little lead particles...
Jeff Allen
J2 Speed and Custom
Old 08-02-2011, 03:08 PM
The WidowMaker's Avatar
TIG only with that.
100% chance you'll see that weld in full sun if MIG welded.
i still dont understand exactally why some show up and some dont. i found out during my build that the lower portion of my quarters had rivets holding them on. nothing else.... there were no issues with hairline cracks visible at any point in time.
"The WidowMaker"
Old 08-02-2011, 03:41 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
It's not the movement, it's the hardened mig weld vs the normal sheet metal. It'll expands differently with heat. And it's worse at a place like the top of the b pillar, where sun would hit in directly.
