Old 08-06-2011, 05:32 PM
Rick D's Avatar
Rick D Rick D is offline
Thumbs up
It really can only go in from the bottom, I was fitting a set today. I always cut a little short and then trim to fit as know two cars are the same. I start with the front of the tub and work it back from there. I use small pry bars to work it back. Also you can mesure the opening and mesure the tub to how much more you have to go.
Rick
