Old 08-19-2011, 08:56 PM
TurboNova's Avatar
TurboNova TurboNova is offline
Originally Posted by jasond26 View Post
I am bringing this up because I have been having an issue with my BS3. Brand new lsx motor and it will not start. Using the BAL feature I never get cam crank sync. I have tried everything, shooting voltage, new sensors. I have stumbled accross this thread and looked at the dealer settings, turns out the cam signal is set for none. It needs to be 5v. Does anyone have the password so I can fix this and get it running. Thanks.
I believe it's "engine"
you will have to key off and disconnect the battery after doing so. This will store the changes.
For the LS engines, they are hall effect pickups so they both should be HED according to the Dealer manual.
None of the other settings are needed for the LS setting.
If you choose "other" then, you need to choose rising or falling. Your input to the sensor is 12v because one side of the sensor has 12v in.
IPU is inductive like MSD type ignition.
Sad when the dealers can't even sell stuff setup for the customer. This is a basic one along with the first post in the thread.
Brian Macy
Instructor
EFI University
www.efi101.com
owner
Horsepower Connection.com
Fuel Injection Dyno Tuning Turbocharging
cell 360-280-6112
