Old 12-14-2011, 09:51 AM
rchaskin's Avatar
rchaskin rchaskin is offline
On top of the frame rail.
see link
http://www.americantouringspecialtie...s/files/10.pdf
Good Luck.
My crossmember is quite bouncy. I am going to add some gussets on the plate to the down tubes.
Old 12-14-2011, 06:42 PM
GeoffP GeoffP is offline
I have the previous design to this but it has very similar frame mounts - they bolt to the top side of the frame. I'm glad I got the first design. It's non-adjustable but appears to be a much stronger design. Mine doesn't move at all.
GeoffP
68 Camaro LS1 T56 3.55 12 bolt posi
Old 12-14-2011, 08:02 PM
usa-69z usa-69z is offline
see link
Good Luck.
strange , this link clearly shows it to sit on bottom of frame rail???
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 12-15-2011, 04:53 AM
rchaskin's Avatar
look one more time.
You cannot see the bolts in the picture.
also notice how the bracket is tucked in the pockets of the floorpan.
It is confusing. I can email you an installed pic if you need one!!
Randy
Old 12-15-2011, 05:22 AM
look one more time.
Randy
Ah maybe im missing something here??? so the brackets are bolted to the top of frame and it sits that high??
Old 12-15-2011, 05:51 AM
rchaskin's Avatar
Yes.
It misses the floorpan by like 1/2".
But it does fit.
See this pic. It is a 70 camaro, but it mounts similarly.
http://www.hotrod.com/techarticles/e.../photo_10.html
Old 12-15-2011, 02:50 PM
Yes.
But it does fit.
thanx all,, i see it clearly now... im a dufus !
Old 12-15-2011, 03:23 PM
Rybar's Avatar
Rybar Rybar is offline
Gav, I remember I had the same issue installing mine. That last picture is correct.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 12-15-2011, 05:04 PM
Blake Foster's Avatar
That is not a great picture, but if you look closly it is actually on the TOP side of the frame rail.
The instructions do not state to mount the brackets to the bottom side. they say Quote" Install both frame mount assemblies with adjustable ends to the frame using the factory holes and tightening hand tight."
sorry you have had trouble i will update the instructions to make it clear that they are to be installed in the original location.
thanks
Blake Foster
www.speedtechperformance.com
Old 12-16-2011, 01:27 AM
thanks
all good Blake ! i havnt been under my car for a look yet just saw the instructions and thought about the long bolts ,, but i see how it fits up now.. thanx
