Old 12-18-2011, 10:57 AM
David Pozzi's Avatar
I meant 6" total travel bump & rebound, so 3" of available bump travel with maybe .5" more lost to a coil over bump stop, leaving 2.5" bump travel before you hit the bump stop. With shocks behind the axle it translates into a little less travel at the axle centerline due to the motion ratios.
3" at the axle is pretty good. Be sure to check your pinion bumper & driveshaft to tunnel clearence. If your trans is angled down to the rear, it will require the pinion to be angled up the same amount to align it, this can cause the driveshaft to be higher than you might think.
Those frame rails do look like they droop to the rear.
David
http://www.PozziRacing.com
Old 12-18-2011, 11:19 AM
Originally Posted by David Pozzi View Post
I meant 6" total trave bump & reboundl, so 3" of available bump travel with maybe .5" more lost to a coil over bump stop, leaving 2.5" bump travel before you hit the bump stop. With shocks behind the axle it translates into a little less travel at the axle centerline due to the motion ratios.
David
thanks David. I've never had one that close at ride height, but the factory rails are bent completely differently than what he's using.
Old 12-24-2011, 09:31 PM
Bad penny is at the limit, or darn close to it.
Old 12-26-2011, 11:32 PM
jamesinark jamesinark is offline
Would there be any downsides to having around 1"-2" more travel in the rear than what you stated ?The roads around here are pretty rough in some areas and any extra traxel could be beneficial.I do realize that ride height would be affected ,but I will have a little over 2" of channeling of the body over the frame rails.Would that not help with the ride height issues that inevitably come along with the extra travel?
Old 12-26-2011, 11:54 PM
channeling...that would help.... David, I thought Steve had fabricated frame rails?
Old 12-27-2011, 08:03 AM
Bryce Bryce is offline
I only have 4" of total travel on my falcon. This is only due to packaging, too much stuff under the falcon with the 3-link and watts.
I have only driven my car on the street at this point and I have not seen any major issues with limited travel. My DD 95 mustang only has 1" until bump stops and only rides hard when I have someone in the back seat.
Old 12-27-2011, 09:06 AM
Track Junky's Avatar
4" of travel minimum should be fine. Do you plan on off roading . Our cars are meant to drive on asphalt. Unless you have some real big buddies that you intend on throwing in the back seat and take every where you go, as Greg Weld would say,"Fuggettaboutit"
Gaetano Cosentino
