Old 02-25-2012, 06:28 PM
69znc's Avatar
69znc 69znc is offline
Kev
I did not do the controller from AutoRad. I have mine fully controlled thru my ECM. THis includes temp they start. temp they stop even after shut down, coming on and off based on the AC and even turning the AC at times. one fan vs two fan at temps all is done thru my Electromotive ECM
It is not hard. and the actual wiring is less and more important integrated with these other variables which I like
Old 02-26-2012, 08:51 AM
KPC67's Avatar
KPC67 KPC67 is offline
Originally Posted by 69znc View Post
Kev
Basically is what you are saying is you have your ECU doing everything that the autorad controller will do but with a little cleaner installation.
Did you get your ECU with a custom program to control your fans? (is that possible?)
Thanks for all the info.
Kevin Carter
Old 02-26-2012, 11:38 AM
Some ECU's have this capability - some do not (running two fans). If not - you can control two fans with the SPAL PWM controller or similar. I like the SPAL version - it is easy to use - water proof - and with the addition of one relay will run twin fans. I like it's strategy of running the fans for awhile after turning off the A/C for a cool down period etc.
I know the FAST EFI has dual fan control... as did my Accel Gen 7 ECU
Old 02-26-2012, 09:37 PM
JustinB's Avatar
JustinB JustinB is offline
Greg, where are you finding the Spal Pwm controllers? From what I have been told Spal is no longer making them and I can't anybody who has some on the shelf.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 02-26-2012, 11:06 PM
Well -- It's been a couple years since I had to buy one... and the place I bought it from (I have two of them) also shows "no longer available".
Sad - it was a nice piece!
Old 02-27-2012, 10:51 AM
ironworks's Avatar
I sell quite a few of the Autorad units. There quality looks like something we might try and build. the PRC units look like miter cut projects with exposed welds. If I'm going to buy something that we use on one of our builds I want it to be as good as we would build or better. The Autorad Unit is really nice quality, all welds are sanded smooth and drilled and taped holes make things clean. AutoRad's radiators are bigger in most cases.
We sometimes run the fan circuit off the ECU or Ron Francis makes a really nice Controller also. It is fully adjustable and uses a wire lead that can hook anywhere to the block. It requires more knowledge to set up as far as a tem gun, But is really clean and does not use a thermostat sender. Just an Eyelet hooked to a bolt on the cylinder head.
The other hard part about the ECU fan signal is getting the AC to work with that properly. The external fan switches address that more easily.
Old 03-03-2012, 03:39 PM
69znc's Avatar
I guess this greatly depends on the ECU. I am very new at this and can easily adjust my temperature and speed of my fans (one or both) relative to the water temp or whether the AC is running from my ECU. I also programmed it to for my AC shut off at certain RPMs and temperature.
Old 02-28-2012, 04:16 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
There are a couple on ebay.
Old 02-28-2012, 07:24 AM
ironworks's Avatar
These work awesome. I sell a bunch of them.
http://www.ronfrancis.com/prodinfo.asp?number=AR-88
Old 02-28-2012, 07:47 AM
I just liked the way the SPAL PWM would run fan #1 at half speed and then ramp up as needed... and would run the fans on cool down mode after running the A/C... and that it was waterproof so you had lots of mounting choices.
But obviously that's a mute point now.
