Old 02-10-2005, 04:49 PM
DCreations DCreations is offline
That looks really good, what kind of black is that jody?
Dave
“Tony Tony Tony, I know that your horny, but there’s
somethin bout that Bush ain’t right”
Old 02-10-2005, 05:04 PM
c.schulz's Avatar
c.schulz c.schulz is offline
Jody,
Long time waiting.Awesome!! Highlights look true and straight.Id love to see it in person.Pics only tell so much with black.
You are right, now the real work begins.Take a deep breath and put your head down my friend.
Again wish I wasnt so far away Id come lend a hand.
And please keep us posted when you can.(PICS)
Your humble fan,Chris
71 RS Pro-Touring thing.....will it ever be done?? Not with out a second mortgage! SOLD
Old 02-10-2005, 05:09 PM
Thanks guys. It's been blocked and buffed, may need a second round but honestly is pretty flat. For now I will leave it alone.
I will keep you updated with pics for sure. And Chris, I wish you were close enough too!
Old 02-10-2005, 05:19 PM
slownova slownova is offline
thats a pretty car. is the subframe in the car still? or what does the cage go to?
Old 02-10-2005, 05:25 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Looks great, Jody. The Marquez Design parts are going to look fantastic on yoru car.
My LS7 69 Camaro
Old 02-10-2005, 06:09 PM
zbugger's Avatar
zbugger zbugger is offline
I see one rather large blemish in that rear quarter....... Oh, wait..... Never mind. It's just you. Car looks great Jody. I'll definitely have to cruise by.
Old 02-10-2005, 06:22 PM
Steve Chryssos's Avatar
Meticulous.
________________
Steve Chryssos
Ridetech.com
Old 02-10-2005, 07:03 PM
The front subframe is out and over here:
I have a 6 point cage in the car, tied into the rear frame rails in the trunk and the welded in DSE frame connectors, and to a plate on the floor up front by the kick panels. The front subframe and frame connectors bolt together with 6 bolts as I wanted to keep the subframe removeable.
Old 02-10-2005, 07:38 PM
wow man thats gonna be a clean clean car when your done. i got a couple questions for you tho...
on your LT1, does it have the gear for the distrubitor on the cam? or did you order the cam that way...?
as for bolting a 4L80E to the LT1, will anyone bolt up to it? or did you have to get one out of a pre-LS1 truck?
any way that car is gonna be K-I-L-L-E-R...
Old 02-10-2005, 08:08 PM
The LT1's have a dist gear on the cams just like a regular small block; they use the gear to drive the oil pump with a little stub shaft bolted under the intake manifold.
The trans is a standard Chevy V8 bellhousing.
