Old 03-14-2012, 01:12 PM
Sorry you had issues with your car and hope your health is OK (a day at the races is always the best cure)
As I am sure you know....excessive overheating can cause ring failure, kills the valve springs etc . And If the oil gets hot enough, It will break down and will not lubricate the cylinder walls, bearings and just kills them.
With the temps you described, I would say you collapsed your rings, maybe scorched a piston and your cylinder walls are now distorted.. aka out of round. Your low oil pressure may be due to the bearing clearances opening up due to the excessive heat
Your car sounds awesome !!! I'm sure you'll make her bigger and badder then it is now
Thanks Jerry. Appreciate it.
Yeah it could easily be and is likely one or more of those issues you mentioned. Won't know til we open it up. Debating on taking it to GG Pleasanton AutoX in 10 days as is. It's just a short peanut course and lasts 30 seconds tops and I don't see more than 5500 rpm.... Hmmm...
Bigger and badder is definitely in the works...
Originally Posted by compos mentis View Post
Much better than cable. That car's got a real attitude you know.
And its about to get even more with what you said is being cooked up at the renowned BMF Labs.
Thank you good sir. BMF Lab techs are hard at work in the lair....
Old 03-14-2012, 04:14 PM
intocarss's Avatar
"Your low oil pressure may be due to the bearing clearances opening up due to the excessive heat"
After talking to my boss this may not be the issue with your oil pressure, as the clearances wouldn't change enough to worry. You may have scuffed a rod or main bearing. Since you're going to run it again, you should check your oil filter for bearing material. BTW I sent you a friend request over on FB
Old 03-14-2012, 06:41 PM
Email me you bonehead... after you and Rich come up with some plan. I have LOTS of engine parts that could be of use to you.
I think you need a big cubic inch small block but with some piston in it so you're not scuffing the cylinder walls and you have some oil control. So maybe a raised deck SBC with your other top secret stuff you told me about.
Big inches is big torque and trust me when I tell you I have a SBC that revs faster than you can catch it! They just have to be built right.
Old 03-14-2012, 06:45 PM
Jerry, Are you advising Mr. Gordon that he should've pulled off the track when his coolant temperature gauge crested 250 degrees and his oil temp needle was buried?
Old 03-14-2012, 07:56 PM
intocarss's Avatar
NAH... He was having toooooo much fun & he has "spare parts"!! I agree with Greg! Build a BIG INCH SBC and let her eat!!
Old 03-14-2012, 08:25 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
250 with no oil pressure? I feel like a wimp, I pulled into the pits after at 230 and a little oil pressure.
Maybe you also have two blown head gaskets?
Matt
Old 03-14-2012, 09:26 PM
Sandbagger's Avatar
Sandbagger Sandbagger is offline
Is that still the 377 in there ? What do you have in mind to replace it with ?
Im on the fence on what to build for myself . I do the same kind of trackdays you do .
Old 03-14-2012, 09:59 PM
10-4 the oil is a little dark so we'll check the filter too.
Oh so YOU are Jerdog? I'm glad you told me!
Thanks Ben Stein... I'll email ya. I agree and do want to stay below a 4" stroke but maximize cubes... so maybe a 420 or 422 with a 3-7/8 crank. I need good cubes to swallow the big ports of my new heads to make decent torque... and yeah, a tall deck block would be ideal.
I like lightweight parts for fast revs.
Hey, it was 240 when I pulled over.... it was 250 when I restarted it to reverse back out into the safe zone off the track.
I heard a good one this weekend re the solution for high oil temps... just don't run an oil temp gauge.
Well to be fair the temps shot up from 201 to 240 very quickly and I was planning on pulling over soon. Maybe just not soon enough.
Matt
230 ain't nuttin for those LS motors I hear... but your motor is also worth 5x as much as mine.
Blown head gasket(s) is a strong possibility... we lost a lot of water since Saturday already too.... but no water in the oil.
Yup... same 377 I've been workin hard since late 2010... and it was built in about 2000. Sucker was built well!
As of now I am looking a bigger cube small block with a serious top end and shaft rockers... I just dont have the power when Im below 4500 rpm and that costs me serious time....
Old 03-14-2012, 10:02 PM
Track Junky's Avatar
Great job at RTTC Dave. I have a feeling your next motor is going to be a serious contender.
Gaetano Cosentino
Old 03-14-2012, 10:04 PM
Fines are double in a work zone.
