Old 03-27-2012, 07:08 PM
strtcar strtcar is offline
Default Lokar Pedal Stiff
I've got the direct fit Lokar pedal in my 67 mustang. Anyone have trouble with the gas pedal being very stiff? I can't even push it down with my hands enough to open the secondaries. I've got the throttle cable pretty short and direct. The way they have this bracket the cable comes out right at the base of the valve cover so I do need to give it some slack to get up towards the carb. Anyone else have this problem?
ps, its very stiff even with no return springs on carb.
Old 03-28-2012, 11:46 AM
JKnight JKnight is offline
I definitely have a similar problem. Maybe not to the extent you are, but it's more stiff than I can handle. I'm thinking about swapping back to the factory pedal.
Old 03-29-2012, 12:03 AM
how is it when disconnected from the carb? could be angle or a binding cable. Quick search and a guy used some silicon lube and it was fine.
Old 03-29-2012, 06:21 AM
Good question ill check without carb connected. I saw that post as well, will try that too.
Old 03-29-2012, 09:23 AM
GoolsbyCustoms's Avatar
GoolsbyCustoms GoolsbyCustoms is offline
if your still having an issue please give Jeff or Eric at Lokar a call at 877-469-7440 and Im sure they will get it handled
www.Goolsbycustoms.com
Old 03-29-2012, 09:32 AM
Will do, thanks.
Old 03-29-2012, 10:18 AM
Sieg's Avatar
Sieg Sieg is offline
Remove the components and test them individually to isolate source resistance?
Cable pinch damage?
Cable bind?
Pictures would help.
