Old 04-16-2012, 05:51 PM
onevoice onevoice is offline
Originally Posted by John510 View Post
Does anyone here have a Glink with a 12 bolt? If so does your 12 bolt hit your shock mount cross bar?
Mine has a 12 bolt, and it does not hit the shock crossbar.
Old 04-16-2012, 08:10 PM
I noticed a couple weeks ago that my shock crossmember is the first thing to hit with my setup too. Specifically the oil filler on the Fab9. Seems like maybe Chassisworks could come up with a solution since both the housing and the G-link are Chassisworks products. I plan to call them soon. I'm actually debating on whether to raise the trunk floor and redo the entire shock mounting setup to gain a lower ride height and exhaust clearance. And I thought this would be a "bolt-in" like setup...
John
'71 Nova (Build thread)
FFR Roadster
Old 04-16-2012, 08:28 PM
Originally Posted by Rybar View Post
I am trying to help other Lateral-G forum members learn from my mistake in listening to a good salesman. Not bashing them for trying to help eachother out to solve a problem. You obviously have an agenda to stick up for what's in your car and who sold it to you and installed it for you. So again. Have fun with your 4x4 67 with correct geometry.
So my advice, do your due dilegence in researching a rear suspension design that meets goals of looks, performance and adjustability. And don't always think a salemans words are as good as gold.
I'm not understanding where you are coming from about your "mistake", because your car has leafs. I don't have an agenda, yes my car has a g-link, no it doesn't sit like a 4x4 (nor does vegas69's). I'm not sticking up for who sold it to me, and he's not responsible for the thing anyway. Alston Chassisworks designed it and built it. The subject doesn't have anything to do with salesman. I got a g-link because one of my priorities was not cutting the floor out of a 68 one owner car like the dse rear suspension requires.
How a car sits visually, is largely dependent on the tire sizes. A 67-8 looks quite different with an 18 335 tire than a 69. Doesn't have anything to do with the suspension, its the shape of the wheelwell. They can all look good, the g-link, the DSE, and yours on leafs also.
If you are trying to help other forum members like you say, why not listen to others who actually have a g-link, instead of inflammatory comments like saying they make a car sit like a 4x4. John510's problem is apparently a rear filler tube on a fab9, the tube or the shock crossmember can be moved. It isnt the end of the world. It's probably not a rear that the suspension was originally designed for, but since they sell it, redesigning the crossmember would be a good idea. One modification effects another, that is hot rodding. Fix it and go on.
You don't like one of the vendors who sold them, I understand that and assume you have good reasons, but it doesn't make any issue his fault. If you read Vegas69's build thread, you will see he has recently changed to double adjustable shocks, and reports improvements from the change. Does this make the stock g-link shock junk? Not necessarily, everything has a price point, and not everyone needs double adjustable shocks. Shocks prices go to the moon, go price out some Penske's if you want a heart attack. If you wanted, you could spend more than the price of a DSE front sub on shocks.
The running height of the DSE 69 test car and Vegas69's car look to be almost identical. If you search, you will find magazine photos of the DSE 69 that look lower, but shots of it at events look like it usually runs a little higher, ie about where vegas 69 runs his. This is because a good performing suspension needs adequate travel, and the limits of travel are the floorpan and frame rails. DSE engineers good parts, and I guarantee they don't bottom theirs out on the frame rail, neither does a g-link. If there are any differences, they are probably because of the difference between the 67, and the 68-9 floorpans. The 67 is different right above the differential, and has less room. The DSE suspension eliminates the issue by cutting the whole area out. Find a picture of the DSE rear with the shocks installed and no springs, fully compressed, and the glink the same way and I bet you will find the whole discussion is splitting hairs.
Bottom line is that any differences are minor at best, and they are both good performance suspensions.
Old 04-16-2012, 09:20 PM
pokey64's Avatar
pokey64 pokey64 is offline
Originally Posted by barraza View Post
I'm not understanding where you are coming from about your "mistake", because your car has leafs..
https://lateral-g.net/forums/showthread.php4?t=29563
//Ed
//1964 Impala SS
//1966 Chevelle (Family Hauler)
//1969 Camaro (Hers...)
Old 04-17-2012, 12:18 AM
Rybar's Avatar
Rybar Rybar is offline
Originally Posted by pokey64 View Post
Barraza I do have a G-Link in my car now was upgraded last year. I did upgrade to the double adjustable Varishocks in the rear. The overall system performance has been fine I was not happy that an engineered kit had to be modified to get right in the car it's designed for. (IE Ride height) I don't have a problem with Frank, he got me my parts and for a good price. He did not rip me off at all. Just logistics and delays. I asked him probably 100 times about the ride height before I ordered as I couldn't find many G-Link cars sitting like the Q-Link cars online. He just kept emailing me the same pictures of a Yellow 69 they did. And I think pictures of your install with a 12-bolt.
FYI Vegas 69's suspension is the older style G-bar/Prodigy Bar/Air bar not the later design G-Link like were running. So comparing his car is a little different, he knows what I'm talking about.
Anyways thanks for the reply, sorry to call your car a 4x4 you should really post some pics of it and your install to help these members out.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 04-17-2012, 09:37 AM
Sorry, I looked at your feature page and it said leafs.
I haven't run mine down to see how much clearance is available at the frame rail when the differential touches the floorpan, maybe I will just for grins. Doesn't matter to me though, mine sits where I want it for the speedbumps I have to go over to drop my son off at school daily.
One of the issues is that many of us, me included, have run our cars at much less than the 3 inches of bump travel that suspension designers like to see. Alston is obviously going to design to reasonable ride standard (3"), and I bet the DSE Q-link has a similar design height. However, just like when we were running leafs, we are free to go lower depending on our personal needs. The problem is that the kit as sold didn't really leave much adjustment room to go lower, whereas the DSE design apparently lets you adjust lower. It is still not clear whether a lower ride height Q-link has any more meaningful travel, ie are we talking 1/4-1/2" or something more? You can't just measure from the axle to the frame and call it good, because I bet DSE's also bottoms before hitting the frame. Hitting the frame directly with the axle on a hard bump would surely bend it. Shorter springs are the easy answer, and there is nothing wrong with them as long as the user knows that they are limited in travel and still has bumpstops. I would still like to see a Q-link and a G-link bottomed, I doubt there is much difference.
The floor cutout of a Q-link is an advantage running tailpipes, but because the coilovers don't drop near as far as a leaf, it is actually pretty easy to run the pipes under the rear without them hanging low. I suspect one of the original reasons DSE went with the raised shock crossmember, was that to get the travel needed, you end up with a shock as long as they are. You can raise it into the floor, or lower it down below the axle. Lowering it down can potentially limit your rim size, ie a 15 rim on a g-link at its lowest adjustment may have the bottom of the shock below the rim. Illegal to run at an SCCA autocross that way. It is all tradeoffs, DSE and Alston took different routes, but arrive at virtually the same place.
The other issue is that I believe a 335 18 is not a tall enough tire, especially for a 67-8, because there is no way to tuck the front tire enough, unless it is short, which ends up eating ground clearance. The front of a 67-8 needs a 25.5 " tall tire. The problem is the lack of very many sizes in the range we need them. A 345 19 @ 27.2"is almost too tall, a 325 19 @ 26.7"might be the best.
Like I said, everyone gets to pick what is important to them. I have a one owner car that I didn't want to cut the floor out of, nor destroy the rear seat structure . It is bolt ons to make it original again, and it would take a concours judge to see the wide inner tubs. Handles well, reasonably priced and pretty easy to install. If I wanted it lower, I would have no qualms getting shorter springs.
Old 04-17-2012, 09:45 AM
DSE and Alston products can't even be talked about in the same conversation. There is that big a difference in engineering, customer service, reliability, and performance.
Old 04-17-2012, 11:52 AM
Rybar's Avatar
Gotta agree with this 100%
Barraza I guess the whole point of this thread is to help people trying to decide on what setup works for thier individual needs. There were none like this as the G-link was fairly new at the time I ordered. There weren't alot of cars running them and Frank had sold/installed most of the ones known.
I understand most of your points for me not being a suspension guy. I've just NEVER seen a thread about issues like this with so many installs in regards to the DSE Quadra-Link. In fact, I don't think I ever recall one complaint to be honest about ride height issues, CRACKED frame rails after some use, having to modify the shock cross members, having to change springs or issues with thier system bottoming out on the floor pan, be it 67, 68 or 69 Camaros or 68-72 Novas. Every car with the DSE Q-link is pretty slammed low and have never heard or read of one complaint.
If the G-link works for you and you need to drive over speedbumps that's great. Just that a thread like this can be very useful for the guy with cash in hand ready to order but not knowing what will work for them for thier needs. I sure as hell would have appreciated it and our members honesty rather than relying on a salesman looking to make better margins on one brand vs another..
Thats why I gotta agree with Todd here.
1969 CAMARO RS
Old 04-17-2012, 01:55 PM
And I would disagree. For a thread to really be informative, it needs to be based purely on facts. Todds statement DSE and Alston products can't even be talked about in the same conversation. while valid as his opinion,is just not a provable or unprovable fact. The Alston was newer when he installed it, and anything new will obviously require more tuning than a developed system. He has learned a lot tuning his, and may end up with an advantage, who knows? IF he comes across a setup that wipes up the DSE cars will he be glad he stuck it out? I would guess yes. Sometimes being an innovator leads you to the front, sometimes it doesn't, but you'll never know if you don't try.
The internet forum world tends to think we are the be all end all, but the truth is that both companies have sold a LOT of these suspensions, many to people who have never even heard of Lat G. For us to draw conclusions based on posts on this forum without any volume information is just flat out irresponsible. It is especially unreliable when some of the issues were brought straight to the internet without the manufacturer even having the chance to correct or respond. The DSE product has been around for a long time, the alston not as long. Does anyone know whether alston has even seen a cracked frame? or is it an internet only issue? A quick BBB search shows DSE had a recent complaint, and Alston doesn't show any. Neither are BBB members. Does that prove anything? Not really. A search also shows Alston has been in business over 30 years, does that prove anything? nope. Does vegas69's car getting beat by a DSE suspended car at an autocross prove anything? Not in the least, considering the DSE guys probably autocross 25 plus times a year. These are big damn cars, and it doesn't matter how much tire or what suspension you stuff under them, on a typical autocross a well driven miata will wax us. Does that mean a miata is a better car? not hardly. The key point is that It all depends
You mention myriad problems, which are real? Cracked frame? yes it exists, apparently on a glink and an earlier version. What caused it? unknown. Speculation centered on welding, but it may just be because the "frame" rail is just weak and not much thicker than the floor pan. I'm not seeing how the DSE design is any better. Anyone with either should probably keep an eye on theirs, especially if you are racing with big HP and tires. Bottoming on the floorpan? I thought the complaint was that it won't go low enough to bottom the floorpan? I don't think this is a problem. Modifying the shock crossmember? This one I don't really understand. The clearance is admittedly tight, but mine was build using the alston jig (I was there and saw it), and mine clears fine with a 12 bolt, a 10 bolt should be smaller, and there is apparently an issue with the fill tube on a fab9. Possibly there are issues when pinion angle is at the extremes, really need more info to pin down. I wouldn't call changing springs a problem, they are meant to be easy to change, and not at all expensive.
You mentioned a vendor, so I'll weigh in. Not because I am trying to defend anyone because I only know the facts of my transactions(which were 100% perfect), but because it is an example of how things get could get blow out of proportion. Probably a year ago, issues of order time come up, business competition is fierce, and a move into bigger facilities is in process, allegations of stealing money are batted around, reputations suffer, business undoubtedly declines(though not admitted to), 6 months go by, more late orders, more allegations, more business evaporates, vendor goes silent. Is it possible the internet allegations helped put the final nails in the coffin? Did the speculation pull the rug out from under a recovery plan? Do you see the similarities? Is the above scenario accurate? I don't know, but I see no reason to do something similar by joining in piling on any vendor because of a few internet posts about ride height. Facts are one thing, speculation is another.
You will notice that many vendors don't have an internet forum presence. Probably because anyone with a beef, can argue forever. There is an old saying about never arguing with someone who buys ink by the barrel, it is in reference to newspapers. The internet has made everyone a newspaper. Air Ride has a sterling reputation, and has people on the forums up to and including the owner. And they occasionally still get hammered about products, even when they do everything possible to help customers. Maybe they just have the profits to absorb more, I don't know. I do know that trying to undercut each other has driven a couple of big wheel sellers under in the past year. And that is just a wheel, imagine how much tougher it would be on a more complex product.
Moral - Don't believe everything you read on the internet or magazines, good or bad.
Old 04-17-2012, 10:29 PM
Just to be clear, I don't have a G Link, I have a G Bar. They are NOT the same thing even though they seem to get thrown in the same bowl. A G Bar is a Ridetech Air Bar with Alston Varishocks. A G Link is an all Alston product.
Alston stuff is a couple rungs down the ladder and that's a FACT. I don't like the design and it's not engineered for the desired ride height of most pro touring cars. A triangulated 4 link is not ideal for our thin rails. Then Alston went and designed his G Link with no front crossmember so it doesn't tie in the rails nearly as well as a G Bar. The DSE upper shock mount not only allows for a lower ride height, but it reinforces the structure of the car and utilizes a panhard bar. I also don't see Alston out proving their products in our venue. For MOST guys, it's a great set up. It's just not on the same level.
