Old 05-14-2012, 05:17 PM
MSTSFabbed MSTSFabbed is offline
Unbelievable... Alright help me understand if you don't mind- Youre interior panels/package tray and maybe dash too(?) are aluminum, I'm gonna guess 3003-H6? If you get a chance do you mind showing a picture of the back side of your door panels?? I'm curious if you butt weld all those panel edges or lap weld them?
When you do your insets like on the trunk floor, are you using a flange die or a buck and blunt chisel? I keep warping the tar out panels with a flange die...I'm sorry I don't mean to pry on trade secrets or anything, you just obviously know what youre doing haha!
Youre work is frickin amazing! Can't wait to see more!
Stephen S.
Old 05-14-2012, 06:30 PM
BBT FAB's Avatar
BBT FAB BBT FAB is offline
Yes all the interior panels are 3003 aluminum. Everything is butt welded no lap welding. Once we have the front all welded we weld the back side of all the seams as well. This allows all the finish work to be done (hammering and sanding the welded areas flat) with out any cracks in the weld.
As far as the offset inserts go we used a step die in our pullmax machine to acheive this. I will post pics of both once I am back at work.
-troy
BBT Fabrications--Mahomet,IL--bbtfabrications.com
Old 05-14-2012, 06:51 PM
Rick D's Avatar
Rick D Rick D is offline
-troy
Man you guys have a Pullmax Nice!
Rick
Old 05-14-2012, 07:06 PM
syborg tt's Avatar
he should have mention the Pull max used to be at Rad Rides.
marty-mj
Old 05-14-2012, 07:50 PM
Rick D's Avatar
Let me guess this one wasn't big enough for Troy??
Rick
Old 05-15-2012, 06:34 AM
Ooooooohhh ok that all makes more sense. Dang that is alot of welding time if youre doing both sides, but that makes good sense. Explains some of the cracking issues I've had. Ah, yeah a Pullmax would make some quick work of that haha. Sweet!
What thickness Al and steel do you typically work with? I'm guessing like 0.030'' AL and about 20-20ga steel?
Thanks for the insight!!
Stephen S.
Old 06-21-2012, 02:07 PM
BBT FAB's Avatar
Small update:
Finished out the under side and still building interior panels
-troy
Old 06-21-2012, 08:21 PM
elitecustombody's Avatar
Nice work as usual. Troy, I was wondering if you make upper control arm for Trailblazer SS, I saw on your website that you offer Colorado arms.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 06-22-2012, 09:47 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
X2!! Didn't even know what a Pullmax was and Googled it and from what I saw, it is a fine piece of equipment to have.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 07-13-2012, 08:53 AM
BBT FAB's Avatar
working on the headliner...
-troy
