Old 05-29-2012, 11:35 PM
phillym5 phillym5 is offline
what is the problem?
Just trying to get the car to run right since upgrading to the 2.0 XFI. Hopefully by the end of the day tomorrow i can get it there....
Old 05-29-2012, 11:51 PM
camcojb camcojb is online now
oh, thought there was a problem with the IAC operation, as in didn't seem to do much.
Old 05-30-2012, 06:37 AM
supremeefi supremeefi is offline
If you need help with the tune let me know. I've helped others here as well.
Mark
Engine builder and tuner.
Old 05-30-2012, 09:25 AM
carbuff's Avatar
carbuff carbuff is offline
It's been a long time since I did this, but I do remember a little. There are 2 different types of IAC as I recall, and the wiring depends on which of the two you used. In my case, I had 2 different throttle bodies I was working with. One had a GM IAC, and one had a Chrysler IAC (I think my Holley TB had the Chrysler unit). Anyway, the wires had to be reconnected depending on which setup I used.
So start with the question "Which IAC am I using?", and go from there. Ensure that the IAC and wiring pattern match. Again, it's been a while, and Jody has more experience with these than I do, but I want to say that if it's wired wrong, it would go full open or full closed when you power up the ignition, so perhaps you can look at what it is doing before starting the engine?
Good luck!
