Old 05-29-2012, 07:54 PM
phillym5 phillym5 is offline
Default Anyone with Fast Xfi..... quick question
Im looking to see what color wires and what order they go into the IAC sensor. Mine were extended a long time ago.. and i have 3 reds going into the connector and 1 black. I want to make sure i dont have any backwards or something. I havent used the IAC because it never worked right...
I traced the wiring and found good connections to the colored wires... but cant find a diagram to make sure they are correct.
Should be red, blue, yellow, and black.
I upgraded to the 2.0.. and its been a nightmare trying to recalibrate all the new settings...... uuugggghhhh.
thanks.
Old 05-29-2012, 08:00 PM
camcojb camcojb is offline
thanks.
late model IAC is
A red
B blue
C yellow
D black
Old 05-29-2012, 08:03 PM
I got that... but what pin is a, b, c, and d supposed to be?
thanks.
Old 05-29-2012, 08:05 PM
thanks.
that is what they're supposed to be. Maybe I don't understand your question. The A pin on the IAC should have the red wire from the ecu. The B pin should have the blue wire and so on. These wires come from the gray 25 pin harness, which also has the fuel pump, fan, and power adder harnesses.
Old 05-29-2012, 08:08 PM
Ok... maybe i didn't see the letters on the connector. I'll take another peak...
thanks!!
Old 05-29-2012, 08:11 PM
thanks!!
the letters will be on the connector and the IAC. Get your glasses or magnifying glass, they're small..........
Old 05-29-2012, 08:15 PM
Your right!!
Thanks!!
Your right!!
Thanks!!
you're welcome.
Old 05-29-2012, 08:18 PM
Dang... It's all wired right. I was hoping it was wrong and it would solve the issue!! O well.
Thanks again!!
Old 05-29-2012, 08:24 PM
Thanks again!!
what is the problem?
