  #13
Old 06-03-2012, 05:53 PM
The WidowMaker's Avatar
thanks guys. this is not a cheap hobby. i just keep telling myself that the wife doesnt need a bigger house.
the motor plan is coming together nicely. i finally got a hold of erik at hke and i dont think theres anyone better to build this motor. just talking to him you can hear how well he knows these motors. the plan right now is still to do a 454 with afr 245 heads, super victor intake and accufab/fast 4150 tb. ill run all this with the holley hp dbc system. running the afr heads will also end up saving well over 1k. anything ls7 commands more cash. the super victor will also help the meshing of old and new technology and appearance. ive never liked the look of sb aluminum manifolds, but the spider look of the ls manifolds is insane.
im also leaning towards the dry sump setup with stock ls7 pump, pan, avaid baffle and peterson tank. its still a couple hundred more than an accusump and autokraft pan but i think its worth the price.
heres the only issue; will the super victor fit? my body is dropped about 3/8 and the motor is raised about 3/4". i have the various heights of manifolds written down, but they give heights from valley mounting surface to carb pad. im unsure of how these valley heights differ between sb, bb and ls (read, same height manifold different motor, does it sit higher, lower or the same). if i could figure this out i can search to see what fits with the other motors. although my motor is about 1 1/8" higher, the accufab tb is about 1 1/4" lower than a holley carb. and i hear the dominators are even taller.
Tim
"The WidowMaker"
