Old 05-30-2012, 05:29 PM
melman109's Avatar
melman109 melman109 is offline
Default firewall help!
I am looking for some suggestions/advice to repair my firewall. I purchased the car with a large square cut in the firewall. I was told by the previous owner that the hole was cut to clear a big cap distributor of course he doesn't have the piece that was cut out and the plate that I purchased to smooth the firewall doesn't cover that area.
Does anyone sell patch panels for the firewall, or would I need to replace the whole thing?
Thanks in advance for any feedback
Mel
80'z Performance LLC
1965 SS Malibu
1968 SS Camaro
1970 Chevelle
Old 05-30-2012, 07:35 PM
yikes, your missing your cowl too....do the whole thing
Old 05-30-2012, 07:45 PM
carbuff's Avatar
carbuff carbuff is offline
Ha! That's nothing... Here's what I started with!
I ended up with a donor body shell that was worthless in other areas, and I cut out the cowl and firewall panel that I needed. It wasn't an 'easy' fix, but the cowl is just spot welded and seam sealer-ed in place. Just takes some time/patience...
Old 05-31-2012, 12:08 AM
ok, bryan wins.... LOL
Old 05-31-2012, 05:15 AM
Rick D's Avatar
Rick D Rick D is offline
They make all the pieces you you need to fix it. I think you can even buy it already smoothed? If you have a LKQ/Keystone in your area they will be able to get you what you need. They bought Goodmark about a year ago. This way you don't have to pay shipping!
Rick
Old 05-31-2012, 07:35 PM
strtcar strtcar is offline
Is there one local to IL near you? I'm local to area and would be interested if I don't have to pay shipping for my chevelle body parts.
Old 05-31-2012, 10:04 PM
melman109's Avatar
Thanks fellas for the advice/suggestions I'll try to get in contact with LKQ/Keystone to see what they can do for me
Mel
1965 SS Malibu
1968 SS Camaro
1970 Chevelle
Old 06-01-2012, 05:13 AM
Rick D's Avatar
Yep down in Alsip, they have about 275,000 sf space. 294 and Cicero ave. they stock quite a bit of the Goodmark stuff. If they don't have it they can get it.
Rick
Old 06-04-2012, 09:29 AM
BobK BobK is offline
As already mentioned, you need two pieces- the firewall itself and the cowl assembly. They're each going to run you right about $300. You'll probably mangle the outer cowl saddlebags in the process of taking it all apart, which will run you another $100 each.
You could try to cobble together some patches, but unless you're pretty good with sheetmetal work, it's likely to turn into a real mess. I just got my new firewall installed this weekend, and it looks great- it's nice to have some clean metal on the car finally.
