Old 06-28-2012, 04:08 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Originally Posted by R.A.D View Post
what kind of oil that sound like it would grab all the dust floating in the air
If there is dust settling on the car than it isn't getting worked on fast enough!
www.roadstershop.com
Old 07-13-2012, 09:02 PM
FETorino's Avatar
FETorino FETorino is offline
Any dust on this 63 or do you have some updates?
Rob in SoCal
Old 07-14-2012, 11:24 AM
67XR7's Avatar
67XR7 67XR7 is offline
stellar FAB work!
1965 Chevelle, Pm me if interested in wheel tool rental
Old 07-14-2012, 03:11 PM
RS-Chris's Avatar
RS-Chris RS-Chris is offline
Supporting Vendor
Thanks everyone! - The 63 is over in the body shop so I should have some new pics soon!
[B][FONT="Arial"]WWW.ROADSTERSHOP.COM
Old 07-25-2012, 02:47 PM
RS-Chris's Avatar
Supporting Vendor
A couple of small updates on the Fairlane:
With the exterior metalwork and leading complete, the car is now over in the body shop.
With the first primer coat down, the bodywork can begin:
Old 07-25-2012, 03:00 PM
RS-Chris's Avatar
Supporting Vendor
While the bodywork is underway, we are beginning a couple of nice details that should improve the car and keep it as stock looking as possible.
The first is a set of stock looking, custom made wheels. The customer wanted the wheel to look like a factory rim, only larger, to accommodate a larger brake and take advantage of the handling improvements and ride comfort of the IRS FAST TRACK chassis.
The idea was to take the look of a '56 Ford hubcap and scale it up with a machined replacement. This would be set on top of a newly machined 18" wheel and center, designed to look like a factory steel wheel, only 18" in diameter.
Old 07-25-2012, 03:11 PM
RS-Chris's Avatar
Supporting Vendor
We will also be working with Classic Instruments to re-create and modernize the existing gauges (which already look quite cool).
First order will definitely be a speedometer with bigger numbers to let you know precisely how much fun you are having with that Kaase motor...
