Old 07-05-2012, 07:49 PM
PhillySpeedNYC PhillySpeedNYC is offline
inside would be great just a heck of alot of work and space is limited since i ran my EFI module inside.
I really was considering reversing it from where it is now since there are 4 holes in my drivers fender apron and just mount the box inside the fender well up top where it would be away from the engine heat and should get some air flow when driving i would assume.
i also am going to upgrade to a newer box my box is the old style which has wires coming out both ends and i want to clean things up a bit.
Old 07-05-2012, 07:56 PM
FreddieCougar's Avatar
FreddieCougar FreddieCougar is offline
I put mine (Mallory, but same idea) on the backside of the radiator support, it's hardly visible there. Paint it black and it would just about disappear.
Old 07-05-2012, 08:37 PM
The MSD in my Nomad is under the front seat on the passenger side.
Old 07-05-2012, 09:08 PM
Lenie's Avatar
Lenie Lenie is offline
Mines under the rear seat in the bird
Lenie
Old 07-05-2012, 09:17 PM
I put mine in the gap between the inner fender and radiator support. My thought was the breze on the outside of the headlight would cool it. I used delphi connectors as I considered wiring up a spare box for events and it make it more serviceable. The more I work on things, the less I like to hide stuff. I ran my wires down and tethered them to the engine block, by the starter, and up around to the distributor.
Old 07-05-2012, 11:12 PM
badmatt's Avatar
badmatt badmatt is offline
dissasemble the box and paint it?
my digital 7 will be behind the dash guys at MSD said no problem.
97 Sonoma "NERA": Pile O Sh*t. Literally.
Old 07-06-2012, 04:58 PM
Shmoov69's Avatar
Shmoov69 Shmoov69 is offline
Mines behind the headlight and totally disappears under the K&N filter there.
If you want bling, just drill out the rivets and polish it since its aluminum.
Jimmy
69 Camaro - Twin Turbo'd
58 Nomad -348 Baby Rat
www.fquick.com/shmoov69
Old 07-09-2012, 08:37 AM
Steve Chryssos's Avatar
My MSD box and coil are both under the dash. Use an MSD Firewall Feed Thru pn 8211. It works great except that the coil is noisy. ...'sounds like Grandpa Munster's basement laboratory.
http://www.summitracing.com/parts/MSD-8211/
________________
Steve Chryssos
Ridetech.com
Old 07-09-2012, 10:10 AM
Musclerodz's Avatar
I put one under the wiper cowl on the 70 Firebird we did and the other I did recently was hid in plain sight one the cameo inside the truck disguised like a heater. As long as they have room to breathe I think they are fine.
Mike Redpath
Musclerodz & Customz
facebook page
