Old 08-01-2012, 01:36 PM
hifi875's Avatar
hifi875 hifi875 is offline
I believe correct me if i am wrong, but you have to match the balancer with the accy system. a corvette system like your would require a vette balancer, like wise a truck accy system uses a truck balancer. camaro(4th gen) and so on. I know i had to use a vette one on my setup
Old 08-01-2012, 04:08 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Very true. Found this site awhile back with some good swap info on it. Not sure why the picture doesn't work (not for me anyway) showing the balancers all next to each other: here
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 08-01-2012, 04:39 PM
aray327's Avatar
aray327 aray327 is offline
take a straight edge (like a long level or metal yard stick) and lay it across the balancer and across your accessories. It will visually show you if they are all inline with each other.
one day my ride WILL be as nice as yours...
Old 08-01-2012, 05:10 PM
parsonsj parsonsj is offline
Steven, those two dampers look the same to me. I don't see why swapping them would make any difference at all.
John Parsons
Old 08-01-2012, 05:55 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
x2. Is the belt the right length and not worn?
Old 08-01-2012, 08:21 PM
boostin05blacks boostin05blacks is offline
I have checked that already. They are all from a c6 vette. The fbody stuff sits 3/4" out further and the truck stuff sits another 3/4" out. Thanks for the reply.
Great link man. All types of good info on there. Again I've checked this already. Thank you.
Did that see the pictures below. Seems like the crank is in 3/16"exactlly.
I know that's what I though when I pulled the one that came with the motor off. I put the one I bought used on just to make sure though. I was over looking at it again tonight and can't seem to find the problem.
Belt is the correct length and is brand new.
Here's some picture with a straight edge from tonight. As stated the crank is 3/16 too far in in relation to the alt, power steering and driver tensioner. Thanks for all the replys and help guys..hopefully I can get a soluition to this issue.
And here's on of the drivers tensioner..
Old 08-02-2012, 01:24 PM
aray327's Avatar
I experienced the same issue on my car. My issue was the alignment of the accessories. I removed them (changed the PS pump) and reinstalled. All the same accessories. However, i discovered the accessories were slightly out of alignment with the balancer and AC pump when I reinstalled. I say all that to say...
After looking at your photos, it looks like the straight edge is not going completely across the balancer. Use that to determine both distance from the block and the straightness of the balancer in respect to the other accessories. Try to get the straight edge across the balancer and go all the way across the alternator pulley. Maybe use a longer one. That 3/16" was more than my variance which was enough to squeal my belt and cause it to jump bead on the AC compressor.
This may be an illusion but it looks like your belt is not running straight across the idler. The photo looks as if the belt is closer to the block near the balancer and further from the block near the PS pump. If that is true, your belt is not running straight across all the pulleys.
I suggest you loosen the accessory bracket and carefully tighten it as you confirm with the straight edge all pulleys are in alignment.
Hope that helps
