Old 08-08-2012, 08:05 AM
Cole Cole is offline
Banned
69 Camaro, SBC 383, T56, Xfactor crossmember, Poly Motor & Trans mts, Factory Linkage, Adaptor plate.
Pedals are mounted using a Zbar.
Thanks again.
Cole
Old 08-08-2012, 08:17 AM
Ron in SoCal's Avatar
+ Muncie Bellhousing, right? Need to determine short/tall or low/wide motor mounts...
Ron in SoCal
69 Camaro in progress
Old 08-08-2012, 08:47 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Thanks again.
Cole
Man, this is like pulling teeth.
Have you installed the clutch, flywheel, Z bar, linkage, pedals, adjusted everything, fired the engine and determined that there's an issue - i.e., that you can't disengage the clutch and/or get a good clutch pedal release point with things as they are now?
It also looks like the transmission is clocked, as if you had an adapter plate intended for a third gen or have the transmission mounted in the wrong set of holes in the adpater.
Finally, have you checked driveline angles. There appears to be a LOT of room in your transmission tunnel.
Old 08-08-2012, 11:00 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Go hydraulic.
