Old 08-17-2012, 09:53 PM
Cold oil pressure doesn't mean much. I've had small blocks with wore out bearings down to the copper have great cold oil pressure and no hot oil pressure. Pull that pan and check the oring while you have things apart.
Old 08-17-2012, 10:04 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Agreed. The point I was trying to make was the high cold oil pressure makes me think the sending unit isn't the problem and the reading is accurate. Meaning yeah I gotta pull the pan
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 08-21-2012, 12:40 PM
Frankenstine's Avatar
Frankenstine Frankenstine is offline
Default Pro Touring Post
Hey Chad super nice build, Not shure you would have the same set up as this guy does (project Schism on Pro Touring .com) but I read on his post page 2 about measuring the radius of the belhousing to make shure the shaft is centered on the crank, or it may cause a vibration a eventuly bearing failure?? just a thought sense you are having a vibration of sorts, he is running an LS3 with a Whipple charger I think, Hope you get it figured out.
Old 08-24-2012, 03:04 PM
Well I've been working on the car a little bit each night this week. After failing to get up the motivation to even touch it Monday I made a deal with myself to at least do an hour a night.
So after a few nights I got the tranny pulled and flywheel & clutch out.
Let me just say that trying to pull the tranny without draining it was a bonehead move. I made a huge freakin mess and still have to add fluid. Oh well now I know.
Also, learned that a torque arm and tight exhaust makes driveshaft removal a huge PIA. Luckily I was able to slide it bad far enough to get out of the way without totally removing it. I had a few requests to Magnaflow when I dropped the car off and luckily they did a good job of routing it so I could pull the tranny without totally removing the exhaust.
As far as diagnosing the vibration I did start it up with the clutch removed and just the flywheel installed. Vibration was still there. Today I dropped the flywheel and pressure plate off to get checked and rebalanced if necessary. They won't have it done until next Tuesday at the earliest so I have until then to wonder about the motor lol.
Also found another present from Pomona Valley Customs in the form of a stripped bolt into my block at the top of the bell housing. They installed a totally different thread than the rest of the bolts. What a bunch of friggen yahoos.
Old 08-24-2012, 03:50 PM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
Good luck with the Flywheel and Clutch. I hope that the fact you got the engine at such a big discount dosen't have anything to do with a potential crank balance problem.
Anyway, just as a reminder I re-tapped several of those case holes, if not all of them, because they had SAE bolts instead of the metric. And maybe two of them seamed on the loose side because of the prior damage. I purchased all new bolts for you also....So, who else had that trans out after me? You could just re-tap the stripped ones to the next size up and/or thread pitch.
Man, sounds like you just can't get a break with this thing.
Old 08-24-2012, 03:51 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
I never drain the transmission except when I mean to change fluid. Instead I use one of these, which you can get in almost any auto parts store:
They seal really well. I needed to put the tape on mine to fill in the gap between the normal size rear seal and the larger seal in the Viper T56 .
The bolt situation on these cars is really a pain. The M10-1.5 metric bolts are almost the same size and thread as a 3/8-16 SAE bolt. If you have both sitting around, you really need to pay attention.
Old 08-24-2012, 03:58 PM
I wouldn't just re-tap the aluminum hole... I'd go with a HeliCoil if you have decent access to it.
My old rule is do it right the first time -- and then you don't have to worry about it forever and ever.
Sorry you're having these issues!
Old 08-24-2012, 04:05 PM
Thanks Greg. I've got until at least Tuesday before the clutch and flywheel will be ready. At first I had a bit of "sticker shock" at the turnaround time but then realized I've got PLENTY of other stuff to work on lol! I plan on spending some of that time checking all the threads on the motor as well as pulling the pan so I can check the oil tube o-ring.
Old 08-24-2012, 04:09 PM
HeliCoil ? the only ones Im familiar with are the spriral type, Which is actually just putting a wound up piece of wire in the hole to make up the difference in the thread gap. Am I thinking of something different? because those work like shiat.
FYI, my advise to re-tap actually means drill larger hole and... well re-tap to the next size. It's basically the same as a new hole, just bigger. I don't recommend re-tapping to the next size by just the means of putting a larger tap in the stripped hole.
Anyway, got any pictures of the HeliCoil system you are talking about?
Old 08-24-2012, 04:02 PM
Anyway, just as a reminder I re-tapped several of those case holes because they had SAE bolts instead of the metric. And some of them seamed on the loose side because of the prior damage. You could just re-tap the stripped to the next size up and/or thread pitch.
Yeah I remember that Brett. Those were the bolts from the trans to the bell housing and in fact I think they are all ok. Have torqued those bolts myself and BOS did with no issues. This new present is from the bell housing to the motor. I don't think you removed that right? I was also assuming BOS didn't remove it though I guess I can ask them.
You aren't the first to raise that question on the motor Brett. I just have a seriously hard time believing the previous owner knew something was wrong. The motor was way too pristine and the dust way too thick lol. I honestly don't think it ever came out of the crate before I took it out. There is a whole list of things I went through that convinced me this motor was never fired after leaving Mast. So if something is wrong with the balance job on the motor I'm convinced it shipped that way from Mast.
That's a cool gizmo. Live and learn!! I was reminded of using a spare yoke trick but never seen anything made for it. I will be looking for one before I reinstall for sure.
