Old 09-10-2012, 09:20 PM
If I was trying to build a show car - the headers would be going back - while I might ponder it a while if it was just a street car -- HOWEVER --- no way I'd pay full price! So I'd give the supplier the choice... return or a big discount to keep 'em.
I'd fully TIG the baffle "just because" -- think of it as practice -- and welding is soothing...
Old 09-10-2012, 10:10 PM
Sieg's Avatar
Sieg Sieg is offline
Compromise..........no one will argue the fact that I need practice! Especially with the TIG. It can be soothing but in my latest example it can also be pretty embarassing. Since time isn't on my side right now I pulled it and added more "security" tacks with the MIG.
Old 09-12-2012, 09:22 PM
Sieg's Avatar
Finally found out what cam the motor has.........because there was two bad lifters and lobes. Motor still has good cross-hatching in the cylinder bore. I learned something I was totally unaware of - zinc additive for flat tappet cams. Obviously I wasn't in the car scene when zinc was removed from oil and this became an issue.
The cam was installed in 1989 and they still sell the pattern.
Edelbrock 5002
Summit Racing Part Number EDL-5002
UPC 085347050024
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 2,500-6,500
Intake Duration at 050 inch Lift 232
Exhaust Duration at 050 inch Lift 234
Duration at 050 inch Lift 232 int./234 exh.
Advertised Intake Duration 292
Advertised Exhaust Duration 300
Advertised Duration 292 int./300 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.488 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.488 in.
Valve Lift with Factory Rocker Arm Ratio 0.488 int./0.488 exh.
Lobe Separation (degrees) 108
Hopefully the crank and rod journals pass inspection.
Old 09-13-2012, 03:50 AM
makoshark makoshark is offline
Go roller. I realize its cost is more, but the peace of mind as well as performance gains outweigh the extra cost. Today, though, roller cam setups aren't as expensive as they once were
Old 09-13-2012, 04:03 AM
If you don't go roller, remember you'll have to run specific oil since the modern "regular off the shelf" oil doesn't contain enough ZDDP for a flat tappet cam.
Old 09-13-2012, 05:14 AM
ccracin's Avatar
ccracin ccracin is offline
The welds are definitely coming along! I give you alot of credit for sticking with it with all you are going through. Keep up the good work.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 09-13-2012, 08:50 AM
Sieg's Avatar
Next motor!
Old 09-13-2012, 09:03 AM
Sieg's Avatar
I guess being focused on high performance off-road and track bikes running high-dollar Motorex and Motul synthetic lubes the last ten years I completely missed the zinc bulletin.
I was really caught off-guard on this one.
Here's the cylinder bore that was done in 1989, don't think it has over 9K miles.
Old 09-13-2012, 09:04 AM
Sieg's Avatar
Thanks Chad I really appreciate it.
Old 09-13-2012, 09:31 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Yeah, go roller.
And ZDDP is just a lot of hype. There's more to oil protection then the amount of zddp it has.
