Old 09-17-2012, 08:05 AM
Originally Posted by SR71 View Post
the 9" axles are retained by pressed on bearings instead of c-clips eliminating side to side axle play. thus the 9" doesn't suffer from pad knock back and has positive axle retention in the event of breakage.
if you are going to buy aftermarket axles, moser makes a kit that converts the 12 bolt over to 9" ford style axle retention.
The 9" definitely has pad knock back issues, which is why Mark Stielow and companies like The GMR Co. spent so much time developing ways to eliminate it. Several of our members who track their cars have had issues.
http://thegmr.com/
Old 09-19-2012, 02:53 AM
BigChevyFTW's Avatar
BigChevyFTW BigChevyFTW is offline
Thank all of you for your replies.
The article I read simply said " we ditched the 12 bolt strait line Drag Strip rearend for a Currie 9 inch.
that could have been a marketing ploy from the magazine.
The 12 bolt is like new with 3.73 gears i bought it from a guy who never installed it. only bad thing is the drum brakes so i will be replacing them soon and using the 12 bolt thanks fellas.
Old 09-27-2012, 04:08 PM
David Pozzi's Avatar
On a 12 bolt with limited slip, a new unit will have no axle end play, a worn plate type will have some end play, re-shimming the clutch pack will reduce it. The Ford 9" has a better axle bearing but still has brake knock back problems. The cheapest solution is to use a floating caliper on the rear. If you want to use a fixed caliper, you need to install full floater axles.
David
http://www.PozziRacing.com
Old 09-28-2012, 01:19 AM
David
This guy knows what he's talking about.
Old 09-28-2012, 09:23 AM
AmKenpo1's Avatar
AmKenpo1 AmKenpo1 is offline
The 12 bolt can be built into a great assembly with the only potential issue being the axle retention. I would recommend having the housing end replaced with with an end that accepts a large Ford/Olds style 3.150"O.D. bearing or a floater assembly. There are C-clip Eliminator kits available but you will need to be sure to use one that has a tapered bearing vs the low friction ball bearing type. You've got alot to consider but it seems your getting some good information here.
Wil.
Strange Engineering
Old 10-01-2012, 05:51 AM
I have seen problems with knock back with both the Set 20 tapered bearings & the ball bearings. Currently I'm favoring the ball bearing slightly. The last rear we used I let Currie talk me into the Set 20 tapered bearing ends & we are not happy with them. The One Lap Camaro had the ball bearings & less knock back but did have a bearing failure.
Old 10-17-2012, 04:55 PM
JD'sTT55's Avatar
JD'sTT55 JD'sTT55 is offline
So if building a 12 bolt (narrowing, buying axles and bearings) which setup is the best? Or do you just have to accept bearing failure, leaks and pad knock back? Is Going full floater the only real solution? But maybe it just depends more on the weight of the car, offset of the wheels and how hard its actually driven on and off the track as to how much problems you actually have.
Old 09-28-2012, 12:35 AM
Might have already been set up for drag racing ie: spool, numerically high ratio so it was problably a bit cheaper to go with the 9.
