Old 03-21-2016, 12:34 PM
QuickTrick's Avatar
QuickTrick QuickTrick is offline
I think you guys are setting a new standard for how clean, and functional builds should be.
QuickTrickers
Ms QuickTrick aka Tess
QuickTrick Media aka Gil
Old 03-26-2016, 05:22 PM
Al,
You and your kids have lost control and I love it.
Marty-MJ
Amazing! I did a tiny bit of smoothing some parts for my car, and every time I see your project updates I can't believe the work involved in it. You guys do amazing work.
Thanks guys!
Extinguisher pluming.
Its all about summitry. A lot of thought was given to the routing process. Notice the lines follow the bead roll in the metal.
This one feed the fuel tank
Feeding the foot well
Feeding the fuel lines in the engine bay
Made some filler panels to fill the factory pockets.
Old 03-26-2016, 05:43 PM
Nice work on the plumbing.
Old 06-27-2016, 06:32 AM
lawkmlaw lawkmlaw is offline
fantastic
Old 06-27-2016, 10:13 AM
NOPANTS68 NOPANTS68 is offline
Holy smokes that work is insane. Love seeing that talent put to use.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 06-27-2016, 12:29 PM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Wow!
Old 06-29-2016, 08:32 AM
Thanks for the props guys. We have some updated to do on the thread when we get a few minutes.
Old 07-05-2016, 02:25 PM
We are at the point were the project is most enjoyable. Most all fab is down and now we are just putting her together.
We received the trans back from RPM. They did their Stage 5 performance upgrade on it. We also replaced every bolt with ARP.
We also replaced the stock slave with RAM's through out bearing.
We also decided to replace the Mantic clutch with RPS twin disc carbon clutch. We have heard nothing but great things about this clutch. More expensive but worth it in the long run.
We added a little heat protection to the starter.
DC Powers made us this alternator to match the 8 lbs Braille battery. They made machined both end out of billet and we had them anodized gun metal gray before they put the unit together.
We used ll Much vapor canister for both the gas tank and the diff. We located on on each wheel well.
Here you can see the breather on the bottom side. Still need to connect the line to the tank in this picture.
Becuase we relocated the gas fill to the trunk, we had to come up with a solution for the vapor line, we used this slick valve that will close if the car were to flip upside down.
Old 07-05-2016, 08:35 PM
syborg tt's Avatar
Al the car looks incredible. I am also looking forward to meeting your kids who have been busting there ass on this car.
Marty-MJ
marty-mj
Old 07-06-2016, 09:33 AM
Beautiful !
