Old 11-18-2012, 04:58 PM
Ijust remembered my parking brake indicator is on my existing gauges too, CRAP! I like your vintage gauges Jeff but I have ben eyeing the UltraLiteII gauges for a couple years now and have to keep brainstorming. Hopefully I can come up witha solution and I don't want to drill into a Carbon Fiber gauge bezel for turn signal lights. You don't have a lot of options on the 68 and I want too keep my other gauges seperate from my tach and speedo.
Kevin
Old 11-18-2012, 05:41 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Kevin
New Vintage can design the gauge the way you want. The problem with Autometer is that you can't put the LED in the gauge. You void the warranty as soon as you take apart the gauge. You don't know where to put drill the holes, because it might cause problems with other parts. Ironworks has modified their gauges, but I rather pay a gauge company to make one that works. That is the best spot for the LED or turn signals is in the gauge. So you like the Autometer Ultra Lite 2 design, so call up New Vintage and they probably can make something similar to that design. I would change it to way I wanted the gauge. Cost a bit more, but in the end you have better design. Lot of options are available. http://www.newvintageusa.com/custom-sets.html
Ok, New Vintage made a prototype setup. That is what I wanted, and here is the thread. https://lateral-g.net/forums/show...t=24888&page=3 So, I talked to Mark, and we made a custom setup for my car. Well, if you go custom then you can make additional changes.
Basically, if you do the custom setup. The cost is a bit more, but you can design the gauge the way you want. I have total of 9 gauges, but 3 are custom made for center dash section. A custom bezel setup could be made, but it will be costly. There is the sun factor, that people tend to forget. So, the factory bezel, well, is rather unique. If you want more gauges, then you can rework the center dash. That is what we did on my 67 Camaro. There is also a dash pad option, that allows you to put the gauges in the pad. http://www.justdashes.com/GuageDashPad.htm
So lot of options available.
Center dash has lot of possibilities, so just think of what you want in that center dash. I prefer people coming up with their own design. Easy to copy, but it is your car, so build it the way you want it.
Last edited by Sparks67; 11-26-2012 at 10:06 PM. Reason: Removed photos for new photo site
